Nut & Bolt Frame-Off 1978 FJ40 Restoration
Fenders are welded to quarters now.
Welded quarter to sill.
Welding on the passenger's side rear quarter is now finished!
Time to start grinding. :(
So you will just grind it smooth and the paint person will smooth it out?
What panels will be original if any? ( not that it matters just curious)
That ground down really nicely.
I'll grind it down fairly flat, then after the whole body has been media blasted and primed, I'll come back over the area with a skim coat of Bobdo. Then I'll block it, and it'll HOPEFULLY be smooth as glass (fingers crossed).
I'm toying with the idea of painting it myself. Not sure if I will though; I'll certainly save a ton of money doing it myself.
Only non original panels (that I'm aware of) are quarters and sill/sill cover.
Uncut quarters are soooo much better looking than cut quarters. Just sayin'....:)
Driver's side quarter is coming off.
Nice work Andrew.
Nice work Andrew.
^^THIS^^
By the way, as far as you've jumped into this project, I believe you could paint it yourself. Paint has come a LONG way over the last few years, and provided you get the body straight, you could do a nice basecoat/clearcoat job. If you mess up any, you can always work it afterwards........
I say do it yourself....
The problem is though, is dust suppression. My garage has a dirt gravel floor; there is dust EVERYWHERE. I'd have to make a completely enclosed system if I decided to go for it. Talk about a PITA.
Emblems are fitted.
Lots of back yard painters get good results. Pick a day with no wind, no pollen, wet the dirt floor slightly to keep dust down, throw up some tarps and go for it
