This weekend I drove to my cabin at Lake Tahoe from Berkeley CA. The temp gauge was indicating normal as the indicator was horizontal, midway between H and C. I turned on the heater about 90 minutes into a 4 hour drive (Sacramento).
Luke warm air, but never warm. As I dropped over the downhill side of Donner Pass (7200ft) at a speed of 65 mph, the temp gauge dropped to a needle width above C. When I hit the relative flat of Truckee, the temp raised back to between H and C. Climbing the steep grade at Brockway Pass between Truckee and King's Beach I had to drop down to 2 (normal) with the RPMs at 4250 for about 5 minutes (about 45mph) until reaching the summit. The temp gauge raised to about 3/4 H. Upon dropping over the
summit again the temp dropped to almost C, then raised to normal at the relative flat at the lake.
Never did the heater blow anything resembling heat. I froze my as$ inside the truck as it was about 18 degrees outside. Returning home to SF Bay Area truck ran at normal temp the entire way, still no heat.
What's up?
Cheers!
What's up?
Cheers!
