new upgrades
which upgrade?
  • 4.88's and a front ARB
    Votes: 12 18.2%
  • SOA
    Votes: 9 13.6%
  • 30 spline longs and front aussie locker
    Votes: 14 21.2%
  • winch and front bumper
    Votes: 31 47.0%
  • Total voters
    66
Hi All:
Ha! This is an interesting thread, at the least because of the different perspectives folks have from different areas.
"Tigerstrip40" I think is James from New Hampshire; I believe it may get muddy there sometimes. :D
I voted for the front bumper and winch; not having real self recovery gear is a big no-no IMHO. One should never assume that another rig on the trail can winch or strap your junk.
Now, on the last weekend of this month I plan on installing some 27 spline Longfields and an Aussie Locker; that is the next step for my rig (I got a winch in 1998!) To me having all four wheels truly turning is more important than a nominal increase in suspension travel, but that is also the type of trails we run up here in the Pacific Northwet.
Regards,
Alan
CUrrently, I have an OME suspension, 35" tires, saginaw PS, an SM420, some beefy steering links, rear locker, and a full roll cage.
Diffs are stock 4.11's and the t-case is a stock '4 speed' t-case.
Here are the upgrades I am considering:
1. 4.88s and a front ARB
2. Spring over with an FJ60 front end.
3. 30 spline longs, Pig Cromo rears and a front aussie locker.
4. Front bumper with a Warn 8274-50 winch
First - tell us what sort of driving you do. And more important what are your current limitations...
I will go for the front bumper and winch....
regards,
Heliman.
just a thought but if i was to ever change my gearing i would buy 3 sets, once you move away from 4.10's the likelihood that someone else will have spares goes down fast. I know that in my club there is always a 4.10 gear set on the trail(in Mark A's truck) and on the hard core runs a spar third member w/4.10 in the back of my truck ever one in the club knows this and mostly thry run 4.10 because of this.
I would look for lower gearing in other places, H41, SM 420, Orin, toybox,
It is nice to do things once and have it be right. That said, a front ARB plus the 30 spline longs would be really nice.
4.88s would be nice, but you can get away without them as Ian has said, especially with the low of the SM420.
A winch is really nice the once or twice a year you need it. Save that for last
SOA-pros and cons here as you know. I've been everywhere SUA the last 8 years, and am now going SOA mainly just to do it myself and check it out.
What's your budget and where do you plan to go in this truck?
Now, on the last weekend of this month I plan on installing some 27 spline Longfields and an Aussie Locker;Alan
Hey Alan,
Why not 30? Just bring the complete set of old 27-spline inners/birfields for spares (if you ever need it).
/td
Hi All:
Regards,
Alan
i think hes from the rocky mtn area,
utah
who knows
My budget is about $1500.
Rock Crawling is what I do with this truck.
moving slowly and articulation are key.
But I have to drive the truck to and from the trailhead.
I have been running the OME suspension and rear locker for a couple of years now, and I don't really have any complaints other than that the gearing COULD be a little lower, and I could have more flex.
On flat ground, the FJ40 really scoots along, but on hills, it really slows down. I plan to run 37" tires at some point, and the 4.10's are too tall for the 2F.
I noticed the limitations of the rig when I was running a trail called 'Cat Canyon'. I was able to do most of the obstacles, but there was one where I had to be winched over (EVERYONE had to be winched over that one, though). And another one that I had to get tugged off of because:
1. my springs weren't flexing enough,
2. I didn't get enough traction.
My front OME springs are pretty tired (I am the second owner of these springs). They are pretty much good for add-a-leafs for other spring packs at this point.
So, I am considering going with some of the HFS 2.5" springs (so I don't have to buy new shocks or have my driveshaft's worked over).
When I am ready to do a SOA, those will be nice and flat, and I can do the SOA and shackle reversal then.
However, I don't want to throw a bunch of money into suspension when I plan on going SOA eventually. But, I can fix the problems with my current suspension, if CCOT will sell me a set of HFS fronts.
Pic of cat canyon:
you wouldnt happen to have some tiger prints on your dash would you?
Suggestions...
First - fix the articulation - from the pic you have several problems.
front shackles are too short
remove the clamps on the leaf springs
check the travel on the shocks
You should be getting a lot more droop than in the pic.
Secondly - you realise the difference between 4.1 and 4.88 is exactly the same as the difference between 4spd and 3spd t/case gears - regearing the t/case may be a cheaper option for you.
Then spend money on front ARB and longs...
Andrew.
The spring clamps in my front sprins have been loosened, but nto completely remove, I don't think that is the problem
But the front shackle is too short, and/or is at too steep of an angle. I have considered this. The shackle is 1.5: over stock
However, since I plan on doing a Spring over and shackle reversal, I have put off fixing that issue until I do the SOA and S/R.
I also have a problem with inverting the front passengers side shackle.
So, I am thinking of gettign the HFS springs, which will give me a better shackle angle.
I do have the internal parts for the 3 speed gears for the t-case, I just havnet really had the opportunity to put it all together.
But I like how quiet the 4 speed t-case is.
:dunno:
Longer shackles should fix the inversion problems also.
Make up some for a test - you just need some flat and a few bolts - put them on and see what difference it makes.
When I built my '3 speed' case it was no noisier than the 4 speed - and if you've got the parts you'll end up with the gearing imporement you want, plus not affect streetability.
Do check shock length - on mine on full droop, the leaves fully seperate - but your arn't doing that - even with the short shackles this should happen - it does on mine when miy shackles are on their stops...
Certainly in the pic, you should have more droop - maybe even try taking off the shock and doing some tests...?
I have a bunch of 3/16" cold rolled bar stock...
I suppose I could make a couple of test shackles out of that?
Maybe add 2-3" to what I have already?
The shocks should be plenty long enough, there is about 3" showing when the truck is sitting flat. They are 12" stroke shocks, IIRC.
