new upgrades
which upgrade?
  • 4.88's and a front ARB
    Votes: 12 18.2%
  • SOA
    Votes: 9 13.6%
  • 30 spline longs and front aussie locker
    Votes: 14 21.2%
  • winch and front bumper
    Votes: 31 47.0%
  • Total voters
    66
Utah
:D I am looking at a couple of different upgrades for my FJ40.
CUrrently, I have an OME suspension, 35" tires, saginaw PS, an SM420, some beefy steering links, rear locker, and a full roll cage.
Diffs are stock 4.11's and the t-case is a stock '4 speed' t-case.
Here are the upgrades I am considering:
1. 4.88s and a front ARB
2. Spring over with an FJ60 front end.
3. 30 spline longs, Pig Cromo rears and a front aussie locker.
4. Front bumper with a Warn 8274-50 winch
Keep in mind, I can only do 1 upgrade from this list.
Vote, and please discuss.
winch, sounds like you have a decent setup now, a winch and bumper would be easy and set it up to get you unstuck if needed. when you tear down to do a SOA, you should have a list of stuff to do as it will all be apart, ie: flipping springs, lockers, longs, rebuild axles, seals, bearings, etc.
Noah
my vote longs
last thing you wanna worry about is busting birfs
I'm for the winch. You currently have a capable rig. If you get the winch you can truly see the limits of it with out worry of not being able to get out of the situation. Then once you know these limits you can determin what is next in your list of upgrades.
Rule #1: Do not stick an ARB up front w/o 30 spline Longs PERIOD!
I'd do a combo of 3 & 4 firstly:
Pig rears, 30 spline Long Superset, Ebay 8274, owner fabbed channel front bumper. Then, save for the front ARB/ 4.88's. Rear, I'd do a full case Detroit, never the little clutch plate style lunchbox lockers. By the time you do all this, there will be more players in the LINK suspension arena, so do that last.
don't waste $$ on a winch yet. go with longs and a front locker. I've been wheeling my 40 for 5 years without a winch and the only time I have been stuck is 1) clearing the trail for others and 2) pulling others out. In both cases there were people around to give me a tug. You'll be surprised at how few times you really need a winch.
That's why I am keeping the Warn hubs.
I'd rather replace a HUB on the trail than a Birfield.
:D
That is a nice thought, however, not very accurate. The three fing birfs that I broke before building my Dana 60 front axle back in 1999 were all while using Warn lockouts. Same situation many times over with a number of other people that I know/have worked on their junk.
Get the 8274-50.
:beer:
Get the 8274-50.
:beer:
So how about Mile Marker hubs? Would they make a good "fuse"?
I vote Winch.
Even with the 30 spline 4340 longfields?!?!?!?!?!?
Come on…we are talking about stock garbage, since that is what you have in your front axle right now….and yes, the axle will fail before the lockout, unless it has been damaged somehow.
With the 30 spline Longs, the only lock out that I would use would be a stock unit that has the chromo drive gear installed in it that Long also sells.
Otherwise the lock out will be the fuse, and when it does fail, and make no mistake that it won’t, it will ruin the splines on your chromo outer and this will not be warranty.
:beer:
:cheers:
I voted for the aussie/longs, because thats what I have. Now that I see you roll with Wasatch guys up in snow country, you may want to do the ARB and gears. Be careful with that switch and save up for longs as soon as you can. Only do the SOA if it is something you really think you need. There is a lot of work involved there. Good luck and let us know what you decide.
Jeremy
