New lift, driveline vibes. Double Cardan Rear shaft?
I’m assuming the stock shaft is used. It’s not unusual for used shafts to vibrate after a lift as they have worn into a rotational pattern.
Based on baldilocks experience it would seem the best solution would be a rear DC shaft.
I personally can’t get past that shaft. A computer balanced shaft will likely have a weight on the slip yoke. I’ve had 2 exceptions to that but is really rare.
And weights want to be as close to the flanges as possible and with the way that shaft is built close is pretty far away.
they vibrate due to the wear pattern in u-joints, good new u-joints should fix that
if you didn't have any vibrations from the rear prior to the lifting of the vehicle, I would use the original DS with OE u-joints, get the shaft balanced and try again
aftermarket u-joints do not perform really nice sometimes
I've done just that. Still vibrates.
I put in OE Matsuba U-Joints, had the factory shaft balanced and trued. If anything, the original 350k slip spline is the concern now.
Update:
Finally got around to having the custom driveshaft checked out by a local shop. My buddy was taking his shafts in for work and was kind enough to take mine in as well.
Shop reports runout at .080" 😳
Normal max runout is .010"
They are gonna fix it and we will see how it runs.
Reinstalled the custom shaft today after it came back from the driveline shop. It's much better than it was before. Still have a vibration between 40-55mph, however it's pretty tolerable.
I think I'll run it as is until I swap the new engine in, at which time I'll also do the engine mounts and trans mount. Then see what we get.
I'm still not convinced this driveshaft is good tho. I do have a friend locally with a buttery smooth CV shaft in one of his 80s. Might have to borrow it for diag purposes....
Anyway- thanks for all the input from everyone.
Final update.
Custom fancy double cardan shaft was never right. The drone of the vibration at 65+ never sat right with me. It was tolerable at first after its trip to the driveline shop, but was still nagging at me and my OCD.
Put in a brand new OEM toyota shaft and its as smooth as it should be. If anyone wonders, yes, I'm a dumbass and spent $1500 on custom shafts and work when I could have just put in a $500 OEM shaft and fixed it.
Anyone wanna buy a custom double cardan shaft? It massages your back as you drive!
Final update.
So did you ever flip your stock rear shaft ? and did it help any? Also seeing if you are still vibration free?
I tried the original rear shaft flipped both directions, no change.
The new oem rear shaft was a big part of the fix. The last of the vibrations were all but eliminated with new engine mounts and trans mount when I put the new engine in last month. See my other thread for photos of the mounts and some explanation.
Awesome I’ll check it out. Thanks for the response. I’m in a money hole right now. Really draining haha
Final update.
get that shaft modded (if its length allows), remove the double cardan and add a slip yoke. keep it spare
Final update.
Who charged you $1500? I usually work with a local shop or JE Reel, Toms and Adam’s.
Noted.
Their online reviews kinda blow.
Keeping them off my list.
I've used high angle years ago his prices were high back then but he was the only one making drive shafts for big lifted trucks one being f250 with 22 inches of lift back then. Got both shafts from Tom for a swap I'm doing for 1100 double cardian front and rear with shipping.
