New Gauge Cluster
Discussion in '40- & 55-Series Tech' started by G_Stratton, Mar 4, 2007.
  1. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    My old gauge cluster was just not serving its purpose anymore.
    Too many mods to the drive train for the speedometer to even be close let alown the fact that the speedometer cable was broken, too short and not the right end for the new trany.
    And as for the rest of the gauges - the sending unit in the fuel tank is shot – the water temp has never worked since I bought the cruiser – the amp meter works but I have always been waiting for it to catch on fire. The oil pressure gauge has always worked.
    I have been using a GPS for a speedometer, but it is a pain in the butt to get set up and it wasn’t uncommon to loose the signal and not know what speed I was going. This is something that has always driven me up the wall, whether I was speeding or not. :)
    So here is my solution -
    [​IMG]
    It is as close of a match as I could get to the old setup
    [​IMG]
    The gauge set is Auto Meter Old Tyme White Series Analog Gauge Kits ATM-1602. I chose this kit as it comes with all the sending units and that the speedometer is electronic and programmable. You program it by putting the speedometer in to program and driving a known 2 miles and then taking it out of program. Imagine having larger tires and different gearing and still having an accurate speedometer.
  2. bsevans
    bsevans Focus on the Journey
    2,008
    Media:
    50
    Albums:
    1
    29
    Jun 9, 2005
    Southern Arizona
    Nice, but where are the turn signal and Hi beam indicator lights?
  3. spotcruiser
    spotcruiser Geezer SILVER Star
    3,459
    620
    Jan 30, 2003
    Western WA
    Looks good, Guy. Seems like you might even have had room for a tach.
    Your turn signals are on the dash, aren't they?
    Todd Bull.
  4. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    Rodger on the turn signals are on the side.
    I still need to pick up a high beam indicator. It will go between the water and fuel gauges.
    I bet I couls have fit a tack in but it would have been a real squeeze.
  5. cruiser88
    cruiser88 SILVER Star
    11,879
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    can i ask where you got your fuel guage:beer: nice work
  6. amg2y
    amg2y
    90
    1
    Sep 12, 2005
    Beaverton, Oregon
    Does the speedo came with the cable? Does it require any mod to fit it to the cruiser? I've been wanting to do this too, but not sure about the speedo cable.
    Any info would be appreciated. thanks...
  7. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    I got as far as getting the wiring harness built for the back the only wires left are the ones from the sending units.
    [​IMG]
  8. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    Thanks
    I bought this gauge kit from Summit Racing on line. The fuel gauge came with a universal sending unit. I haven't installed it yet so I can't say how easy that part of the install will be.
  9. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    As you can see from the picture with the wiring in it, this speedo doesn't use a cable. It uses a sending unit that attaches where the cable would normally on the transfer case. You then run a wire up to the speedometer and as I stated before, you can then program the speedometer to match your gearing and tire size.
    The only thing I’m not sure of is will the sending unit fit a Land Cruiser speedo cable output. I’m running a Dana 18 t-case… you know I have the old 3 speed t-case… I check it for fit. :)
    I checked the fit of the speedo sending unit to the 3 speed t-case. It threads on just fine, but the square pin they provide is not as big as the toyota spedo cable end. you would need to shim or fab a new pin. I would think a pretty easy thing to do.
  10. DiHrdBowTi
    DiHrdBowTi
    123
    Jan 7, 2006
    Reno
    When I did my cluster I went to the local speedo shop and she pulled out a box of pins and matched the sender to the cable gear drive in the t-case.
  11. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    Nice - I see your running dual fuel tanks.
  12. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    those sure are pretty,
    nice wok man
  13. SteveO
    SteveO
    306
    Mar 2, 2006
    Calgary AB.
    Where'd you get that guage panel? I really like the look of that one. Thanks. ....Steve
  14. 78-FJ40
    78-FJ40
    428
    Media:
    1
    17
    Dec 20, 2005
  15. 73fj
    73fj Tho at sumbitch in ayer!
    1,170
    Media:
    36
    Albums:
    1
    209
    Mar 16, 2003
    Grande Prairie, Alberta, Canada
    Has anyone purchased the gasseling panel? Is it plastic? (sorry no hi-jack intended)
  16. G_Stratton
    G_Stratton
    191
    2
    Feb 17, 2004
    Sedro Woolley WA
    Those are sweet. I'm not unhappy with the one I made. If my cruiser was more show then trail I would definitely get one for the cleaner look.
  17. mr_manny
    mr_manny
    1,655
    13
    Apr 10, 2004
    san pancho, ca
    sweet panel :cool:
    just not feelin the two fuel guages...
    I would have added a switch and used the real-estate for a fuel pressure or even a vacuum guage :D
  18. landcrusher909
    landcrusher909 Hobbyist SILVER Star
    4,929
    Media:
    30
    Albums:
    2
    1,496
    May 6, 2005
    Southern Calif.
    Man thats nice lets see some pics after its installed
  19. raiderfan
    raiderfan
    23
    Nov 11, 2007
    Oceanside Ca
    Nice panel. I am looking at doing the same. Did you get all the gauges at summit? I have the speedo installed by the PO but haven't been able to find the matching guages.
  20. 35snmud
    35snmud
    250
    Oct 25, 2007
    Mountains of Northern CA
    On their page it says 1/4" aluminum. Anodized or powder coated.
