Need Help Diagnosis
Does someone have the time to help her along with this? I'm going to be out of pocket for the next couple of hours...
Just off of memory, the .5 tells me the EFI Relay is toast.
Or the 15 amp EFI fuse is blown (more likely)
The red wire with the yellow stripe (pin 2 of the EFI relay) should read +12 all the time. That is the feed from the 15 amp EFI fuse which is fed from the fusible link.
The solid brown wire (pin 1 of the relay) is ground (0VDC)
The solid red wire (pin 3 of the relay) is the logic coming from the ECU to initiate the relay. It should be close to 0VDC when the key is not in the ON position. When the key is ON, that should go to around +12 or so. That means that the ECU is firing the relay and the ECU thinks that all systems are go.
The yellow wire with the red stripe (pin 4 of the relay) is what feeds +12 to the rest of the EFI system/Fuel pump/etc. This will go to somewhere around +12VDC when the relay is energized.
This is the way the system is supposed to work.
WOW you ARE good!! I tested the ECU wire and it was 10.78. & Thank you!!
OMG what does that mean :crybaby:
It means you still haven't read the first page of my EFI diagnostic flowchart that I gave you. I'm not breaking your balls, but you're taking a crash course in 3FE diagnostics. You need to read your materials.
OK, so we now know that the ECU is trying to fire the EFI relay. Please refer to step 4 in my flowchart. Below is a picture of the diagnostic connector on the passenger side of the engine compartment mounted on the firewall. You want to see +12 on pin 8 (B+) with the key in the ON position.
I want to make sure you're on the correct wire. With the key OFF 0VDC (or close) and with the key ON +12 (or close). Please confirm.
No I did, several times! I panicked. Plus I'm an experiential learner. Now that I tested the wire I understand the flowchart.
OK bad news, I had to return the multimeter to its owner.
Good news, I have a confession to make... I pulled the red wire that goes to the fusible link & put it on the brass nut, and the engine started. It ran strong. Tape wouldn't hold it well enough, I had to press it down and have my daughter turn the key.
So does this mean its just the relay?
Confused. Brass screw is fed from the fusible link and should be +12. The colors at the relay could be wrong as they have been molested. Solid red wire should be from the ECU that fires the relay. I don't have a clear picture of what was done to the original wiring. At this point just replace the relay and see what you get. I don't know what wire you touched to the +12 screw to get it to work, but obviously it was the correct one.
Had to have been the load side of the relay, pin 4 yellow with red stripe. That would bypass the relay.
In any case, you proved that the rest of the system is functional and you can now focus on making things correct in the fuse box as well as the rest of the truck.
I will also say that you shouldn't really make a habit of touching wires to +12 terminals like that. Had you chosen the wrong one, at best you would have smoked a fusible link, at worst you could have caused much more damage.
I coached her through PM's exactly what to do to get it running. Do you know exactly which relay swaps with the EFI relay? I think if she swapped the relay out she could at least drive to the parts store and get a china relay for now.
I was coached, I just didn't want to call out the coach. I looked at swapping with the m3 relay, but the wires were not straight forward. Nearby auto store has a China relay waiting for me, just have to get there.
Here is a photo of the relays in the kick panel. The top left relay is the same part number as the EFI Relay and can be swapped in to get to the parts store. I can't remember what this relay is but I think Jon posted it above what it does...
This response is exactly why I came here. I've never been treated differently by other LC owners. Its the one group of people in the world I get respect from, and no one ever tells me to give up and "get something newer". I'm actually in a really desperate situation, and if these guys didn't help me, I don't know what we would've done. My little girl depends on me, yet I have no one to depend on. Because of these guys, she watched her mom accomplish what was impossible when we started. She was by my side the whole time learning and helping. It really sucks someone would down on the gentlemen who made that happen. Those 9 pages are one of the awesomest things to ever happen to me, and I'm gonna honor their time & effort by continuing to learn, paying it forward, and never downing on others for trying.
I posted a while back (I can't remember where exactly) about a time I needed help. The long story short is, I was going through chemo. I had been battling cancer for over two years. Had blown through over $900k in cash fighting cancer trying to stay alive. Married and two kids and was forced to move in with my mother-in-law. I was virtually broke. The only vehicle I owned was my 1992 80 that I had purchased new but was now 18 years old. I relied upon this vehicle to get me and my wife to work, kids to school, and myself to chemo (three days per week). It was literally our lifeline. I had let some maintenance get overlooked. My knuckles needed rebuilt and my birfs were toasted. My 80 wasn't real safe. On top of that my starter and alternator were going bad. I was carrying a spare battery in my truck to swap out when the other battery got to low to start my truck. It was not a good situation. I posted on the local Hoosier Cruisers Clubhouse forum about needing to do my knuckles but never have done it before and need guidance. And also about the alternator and starter. The local club had a "Tech Day" and invited everyone down that weekend. Guys brought parts, tools, and elbow grease. They wrenched on my 80 for 8 hrs. New birfs, knuckles rebuilt, starter, alternator, plugs, wires, distributor cap, etc. They made sure my 80 was safe and reliable for my family. I had never met or communicated with any of these guys. Oh, and they got all of the parts donated to me. It didn't cost me a thing. I couldn't have done any of this without them. I don't remember their names. I never saw them again because I moved back to Iowa a few months later. But they will forever be in my heart.
A few months after this I heard about a guy in Texas needing a new 2F motor for his FJ45. He was a Vietnam Vet. His motor had thrown a rod. I had the 2F out of a FJ40 that I had pulled to do an LS1 conversion in 2004. It was sitting on a pallet at my old shop still. I was able to donate it to him and the guys in Dallas donated their time to get him up and running. This is how the LC community works. The greatest group of people in the world. Generous, loving, giving, helpful, and seeking nothing in return. I don't know how many times I have given or received parts to and from various guys around the country. No charge. Just "here, I'll send it to you." My son and I were talking about it today. I'm going to make a list. It is quite incredible.
Welcome to the club. Some day you'll be able to share your knowledge or more with another member and you will jump at the chance. And you will love every minute of it. :)
