Wow. That is inappropriate and rude to say the least, not to mention completely juvenile. Now pretend you're an adult and apologize.This thread was started 10 days ago and has 9 pages. Had I started this thread 10 days ago it would be 10 pages back in the archive with 1 reply ! That's why I'm starting a new account with a hot chick in the avatar. Maybe do some pictures of a good looking gal in some exotic location w / a landcruiser and say that its me ! Then when I have a question that doesn't involve what size tire or lift to choose I will just use that account.
It's either the defogger relay or the blower high fan relay. I can't remember which one. The part numbers are identical and they are stamped on the metal can.I coached her through PM's exactly what to do to get it running. Do you know exactly which relay swaps with the EFI relay? I think if she swapped the relay out she could at least drive to the parts store and get a china relay for now.
I love watching this thread. Could not imagine a more knowledgable, helpful group!It's either the defogger relay or the blower high fan relay. I can't remember which one. The part numbers are identical and they are stamped on the metal can.
Good job on the "stealth" diagnostics.
In that picture your engine is not running. All of those dash lights are supposed to be on in that case. If the CHARGE; A/T; BRAKE light remain illuminated when the engine is running, then there is an issue with the charging circuit.Update...
This morning when I put the fan relay on, it started up strong and I ran it awhile. I pressed the gas and listened quite a bit, and everything sounded good. It ran more than 10 minutes, just making sure the battery was charged.
Then, I shut it off so we could get our stuff together to leave. It took us awhile. The second time, the battery was totally dead. I got clicks. So I got a jump, all was well, drove 6 miles, felt great, sounded grear, got the EFI relay, no problems.
Until I pulled into the driveway. It died. Stalled? My vocab isn't so great. Put the EFI relay on, put the fan relay back. Put a charger on the battery, started up, died again--didn't respond to gas pedal. CEL came on.
Rinse & repeat.
Tried the paperclip thing again and the CEL blinked but no code. The battery charger showed it was charged.
I searched the tech forum...all I can come up with is alternator.
I agree that toyota alternators are the way to go.... However I have had my rig a few years now and have the receipt from the PO who had the alternator replaced more than a couple years before me....at least 4 years on a non toyota alrernator with no issues. Having replaced more than the lions share of alternators on toyotas as a shop owner/operator I never had issues with return customers with aftermarket alternators...just replace the battery when you do the alrernator @Sparrow777 . The battery could have been too deeply cycled too many times to be any good, could potentially ruin the new alternator, which is a common problem because some people don't know any better or are too cheap.I believe you are correct. Someone else will probably prove me wrong, but that seems to be the issue. It isn't difficult to replace, but you should definitely get one from a Toyota dealer. The ones sold at part stores don't seem to last very long. Maybe a week or two, sometimes a month or a little more.
See all the warning lights? That is an indication there is an issue with the charging system(the alternator).
Just a small update, I looked at the diagnostic code again. It blinks 2 times a second. I guess it comes down to checking the voltage.
I went ahead and reached out to the recommended vendors for the alt.
I'm going to eliminate the fusible links & alt before checking the melted harness. Unless there's a way to get to it besides taking the radiator out. I might just fix that regardless. The humidity and mosquitos keep talking me out of it tho.
Also known as percussive engineeringMmmhm. That could be code 11, momentary interruption in power supply to ECU. There is nothing wrong with the "throw parts at it" method of troubleshooting. Shady mechanic shops make careers out of this method. However, there are less expensive ways of checking an alternator than that. One free way is to go to your local parts store and have them test it. Same with the battery. I strongly believe that you have a loose connection in the rats nest by the fusebox or maybe a short that is causing the random dying.
I advise the jiggle test.
This method has been used by myself on multimillion dollar pieces of military hardware to fix random problems.
1. Start it let it idle.
2. Jiggle wires!
3. Isolate the connection by observing for sparks, or a dead engine. If you jiggle a wire and the engine dies...there's your problem.
