Need Help Diagnosis
Borrowed this...do disconnect the battery first?
Home depot sells Multimeters as well. The Klein brand is pretty decent.
This model is easy to use, auto ranging so you don't need to know what you are measuring, just press the V button and use the test leads. The readout will tell you what you are seeing:
http://www.homedepot.com/p/Klein-Tools-Auto-Ranging-Digital-Multimeter-MM500/204337793
Here's the same unit on Amazon Prime if you like to shop online.
http://www.amazon.com/Klein-Tools-MM500-Ranging-Multimeter/dp/B00EO2HFPI/?tag=ihco-20
It's a great tool both on the car and around the house. Cheaper models will get the job done, but they will have a dial with a bunch of positiosn that you'll need to know whether to set it to AC or DC, and what range you expect to see and select the proper dial selection to get a good reading.
It ended up being the cheaper dial one a neighbor had.
I forgot to add this earlier...the red wire with the burned yellow sleeve...I haven't figured out what it goes to but I tried to remove the sleeve to see what it looked like and here it is...its all melded together...
There is a brass screw in the fuse box along with the efi relay. You need to check that for 12 volts also. If you dont have power there i would suspect the fusable links by the battery as your culprit.
Do I disconnect the battery first? I checked the screw after I disconnected the battery and it read zero.
I took the coolant overflow tank out and found this. I think a previous owner had a battery fire? This may be unrelated. It looks old.
Nope. You need the battery hooked up to check voltages.
With the battery hooked up, check for voltages at the brass screw, across each of the fusible links.
The with the battery UNHOOKED, measure the resistance (Ohms) across each of the fusible links.
Make sure you don't let that exposed metal touch anything else metal or it will short out. That "yellow sleeve" is a butt connector and the yellow stuff is insulation. That connection is the output from the relay. If you don't have +12V there with the key on, it won't start. If you short it out (touch it to metal) it will pop one of those fuseable links, be careful not to do that while testing. It's tough for any of us to explain what to do to fix this, but if you do your part you'll be cruising in no time.
1. make sure those bare wires are not touching metal or other bare wires!
2. Turn your key to "run"
3. Turn the multimeter switch to "20" under the "DCV" section at about the 10 O'clock position.
4. Firmly press the tip of the black lead into a good, bare metal ground point. That missing bolt hole in your thermostat housing would do nicely.
5. Take the tip of the red lead and place it on the bare metal under that "yellow sleeve" and see what you get. It should be +12 volts or so.
We already think it will read zero, just want to confirm. Also check that lug in the fuse box. Any juice there?
The burned yellow red wire spliced to the red one is a problem...it was probably groundin out under the efi. Fix that first...no metal should be exposed. The green wires spliced into the red yellow should also be fixed, crimped and wrapped, they look to be connected correctly. Those are all wires from the efi - the relay is probably toast also along with the fuse.
The yellow wire with the red stripe feeds everything on the ignition side of the house, including the fuel pump. My idea was to have her test and confirm there is no power there, and if not, then continue down the line from that point, find and repair the short. It would take one of us five minutes to get this thing running, but explaining exactly what to do step by step to her is challenging. I'm out, I don't want to confuse the situation anymore. Good luck OP!
Is there any point to testing the fusible links at this point? If so where exactly? The metal thing on the end or somewhere further down? Its a lot of plastic further down.
Does someone have the time to help her along with this? I'm going to be out of pocket for the next couple of hours...
Just off of memory, the .5 tells me the EFI Relay is toast. The brass bolt being at 11.65 tells me the battery is probably low from sitting and trying to start the truck. If the battery was fully charged my guess is that it would be reading the 12+. You could check the battery with the meter. Red probe to red post on the battery, black probe to black post on the battery. Should read pretty close to what you are getting at the brass bolt.
If I'm not mistaken, SOMEONE CORRECT ME IF I'M WRONG, the fusible links must be ok if the brass bolt is getting 11.65 volts. If the fusible link was bad then the brass bolt would read 0.
OK it measured 12+ at the bolt and the battery. Without the key in the ignition, cos I forgot.
So the wire being dead signals the relay is dead? Or the wire is bad? I went ahead and wrapped that exposed bit.
Yes, the brass screw in the fuse box is fed from the main fusible link and provides power to everything in the fusebox.
FYI I put a new fuse in for the EFI relay. I also recrimped and wrapped those funky green wires everyone says is wrong. I would get started on wiring it correctly, but I don't have extra wire sitting around. Just a 4ft length of thick copper wire---was going to replace my battery ground wire with it.
At this point I'm guessing I need to get a new relay and some wire.
