The top section of the bib comes off with 6 or so small bolts. You need to remove the latch assembly and the horn bracket. You'll see 3 or 4 plastic harness clips sticking out of the top section. Squeeze those with a needle nose to pop them off and you'll have access to the entire front conduit.Just a small update, I looked at the diagnostic code again. It blinks 2 times a second. I guess it comes down to checking the voltage.
I went ahead and reached out to the recommended vendors for the alt.
I'm going to eliminate the fusible links & alt before checking the melted harness. Unless there's a way to get to it besides taking the radiator out. I might just fix that regardless. The humidity and mosquitos keep talking me out of it tho.
You'll want to remove the battery and battery tray and coolant overflow bottle to get a good look.
