All you need to do is turn the key to the ON position. You do not need to crank the starter. If the CEL is on steadily, then the EFI relay is energized and the EFI system is ready to go.Ok. So, let's back up a second. When you try to start your truck do you get a "check engine light" as it's trying to start? Do this right away and report back. Thanks.
All of that wiring is a clusterf#$% and needs to be figured out for sure. At the very least it needs to be cleaned up if not eliminated if not needed.
Closeup of wires in relay
Please keep in mind that NOTHING in the driver's kick panel and NOTHING in the vacuum system will prevent spark. There has been a ton of guesses and some good and bad information in this thread, but if the CEL is not illuminated when the key is in the ON position BEFORE cranking the starter, this truck WILL NOT RUN. You guys can guess at stuff all day long, but you're pissing into the wind.
In a previous post I said that power source issues need to be looked at first. There are 3 fusible links off the positive battery terminal. Since the starter cranks the motor, we know that AM1 is good, however there are 2 more that need to be intact. A previous post referenced the brass screw in the fuse box. That is a good starting point.
I gave you my EFI troubleshooting flowchart a few days ago which will help diagnose the cause for the CEL not illuminating. You really need to go through that step by step and document your findings.
There are most likely several issues with this vehicle, some of which will cause it to run very poorly. However, while everyone here is trying to help, we really need to stay focused on the very basics. Let's get this motor to fire first, because without that we have a very large paperweight.
(sigh) This looks like a poor attempt at fixing a contact or wiring issue in the fusebox. While I understand why, I cannot accept how incredibly poorly this was done.Closeup of wires in relay
Understood. There is a LOT of confusing data in this thread. I was just trying to clarify and keep things on track. As we say in showbiz, we need to take it from the top.Correct that nothing in the kick panel will prevent spark. But if the EFI Relay is bad there are others in the kick panel that are the same part number and can be used in a pinch. That was my point in showing her where they are.
The wiring to and from the EFI Relay is very suspect. And seems to be a good starting point.
If something shorted due to the outstanding wiring in the fuse box, then we need to verify power source. The original poster said that the battery terminals were suspect. Again, we need to verify power source. The EFI relay may or may not be the issue, but without knowing where we stand with +12 getting where it's got to be, we have nothing but guesses.
There is a diagram with pin numbers on the side of the relay's metal can. Attached you'll find a PDF with the correct wiring for the EFI relay. Most likely these wires were pulled out of the fuse box housing to "cure" an intermittent issue which we have yet to determine.
Agreed. There may be multiple issues. I think the wiring at the fuse/relay box has to be the first place to start.
I wish I still lived in Dallas, I'd drive down there and look at it since I'm off work anyway. (This is the only time I've ever wished this @LFD2037)
This sucks for the OP but it is one of those things that she will know her 80 so much better after having gone through this. Hard to see the silver lining right now but it's there.
You have great taste in vehicles, lousy taste in me.
Y
Take a picture of where the EFI Relay is supposed to plug in. (Like hold the relay off to the side and point your camera down in to the box and take a picture from above. We need to figure out why those wires are plugged in to the relay.
I've been on the road for the last month and I have a long list of things that need to get done both around the house and to the vehicles. Sometimes MUD takes a back seat.Yeah......That's why we kept asking for you........![]()
What you want is a "digital multi-meter" from Radio Shack or wherever you can get one. You need to learn how to use it before testing things on the truck like DC VOLTAGE and RESISTANCE. We'll start with voltage when you are prepared.I don't have an amp reader. I'm going to see if I can borrow one from a neighbor or get a ride to buy one.
