Need Help Diagnosis
I'm going to try and make my initial post thorough so if anyone can help me it will be easier.
I've got a '91, had it about 4 years. Only mod is a lift, and everything else original. About 238k miles presently. I've been determined to do any mechanic work myself and learn as I go along. Until recently, no opportunities for that. Over the past year I've noticed it idling rough. It got slightly worse over time. I was so busy working several jobs + kids honestly I couldn't find the energy to do more.. i just prayed a lot and was thankful when it started every morning. I've had some problems getting it to start immediately after turning it off, like at the gas pump. The battery wiring looks terrible...I was too busy myself so paid a mechanic to replace it. He took my money and didn't do it. I've gotten frequent oil changes and a new battery, which seemed to fix the problems. But not long after the new battery, one night, pouring rain, almost home, intermittent loss of power. There may have been a clanging or knocking sound, but its hard to say in the storm, ect plus I was panicking. I got it home, and called a friend who is a mechanic, to help. Well, "friend". From there I got new plugs (highest quality) and wires, carb cleaner, and fuel filter. "Friend" left halfway through installing wires and it took me 3 days to get on right. It didn't want to start afterwards, and when it did, it coughed up lots of smoke, wouldn't go past 20mph, and died after idling very rough. This friend made me give him 70$ for the just carb cleaner, when later I saw it in the store for 4.99$ :(
I installed a new ignition coil, as the plugs weren't getting spark. Wouldn't stay running for more than a minute. I thought maybe the carb was clogged up. I put more cleaner through, as well as changing out the fuel sock. I made sure the wires were on right. It needs a jump to start, but when it does I have to keep pumping the gas to keep it going. More smoke---gray or black smoke. Then it dies. Last time I tried to jump it, I think I got a corona discharge from the battery, only on the ground side. It was late and that scared me, so I decided to regroup and ask here. I didn't try to start it enough after the sparks to see if the cleaner worked. I added fuel and oil cleaner as well. I've heard it can take quite a few tries, and might need to run awhile to see.
A few hoses cracked from dry rot and were replaced. Possible vacuum problem? The fact I feel like this has been building up and it was intermittent tells me its not electrical? At this point I've researched so much I have more ideas than I can handle. I also don't have enough working knowledge to rule things out. So the symptoms are loss of power, rough idle, dies quickly, and smoke. I was going to check the solenoid function today to see if the needle is stuck, blocking fuel supply.
I promise I'm never letting a mechanic or a man touch or lend advise on my truck again, unless he's a fellow Land Cruiser owner. I can't believe how much bravado seemingly sane men feel like they need to show because a lady is driving a real truck. Sorry for the vent, but I'm a little emotional right now. My truck has been sitting a few months while I'm troubleshooting & its my only transportation & I've got kids :/ I can't get sidetracked with this repair. Hoping for some good news and thank you!!! And yes it has a full tanknof gas and a fresh oil change.
Plus, if anyone has advise on preventive maintence specific to my year model, I'd love it. I've been able to do a few things so far like the sock, brake calipers, new EFI relay, sensor for emissions, ect.
Unless all the smoke is from the carb cleaner then sounds like to much fuel could be a bad injector or wiring associated with them. Check your oil to see if its over full and smells like gas
Yes it wasn't smoking before the carb cleaner + checked oil & it good. Injector/wiring, could be, adding to my could be list. Thank you!
I suspect you have several things going on. I'm not really up on the earlier trucks (ours is a 97 with the 1FZ motor), so can't help much. Will stick to one issue that seems to stands out and may be able to help with.
The intermittent start issue sounds very similar to that in the later model years. Our truck is currently suffering from it. There are two primary causes. Bad contacts in the starter/solenoid is one. This will cause the starter to cut out as it turns. Keeping the key turning the key until it catches and starts will sometimes work and has so far when it's shown up. The cheapest solution is to just R&R the contacts, but the whole unit can be R&Red if you feel it's needed.
The other issue is the ignition switch that sits behind the key cylinder that you stick the key in. It is NOT the key cylinder, although older trucks can also experience wear with it and the keys which can cause problems with being able to turn the key. The ignition switch is actually an electrical problem and so far it eventually starts on our truck. I can jiggle the key in and out in the key cylinder with it in different positions and this seems to move the contacts in the ignition switch just enough so they do finally establish contact and start. Some people just wire around this particular contact and install a separate Start button. R&R the ignition switch is more straightforward. In any case, jiggling the key is still working here, so saving my cash for now.
Do your intermittent start issues sound more like one or the other scenario? In my case, I have both issues going on and likely need to address both, but you may be able to determine it's just one issue.
Well to start i would recheck all the spark plugs and see if any are wet with fuel. You will probably need to replace them or they can be unfouled by heating them up real hot while they are out of the truck
I would check all of your vacuum lines first. They are cheap and fairly easy to see if they are cracked. EFI relay is fairly common for the "won't start after running" symptom. Where are you located? Maybe a local MUD member can help you. There are local groups all over and if there isn't there is usually someone that would be willing to help you.
@Tools R Us is one of the authorities on the 91 and 92 trucks. Since I tagged him, it should get his attention.
I'm thinking plug wires in the incorrect order or possible timing (someone rotated the distributor) issue. I'll let Tool answer before I attempt.
@jonheld is who I would go to for anything 3FE related.
@jonheld is the '91-'92 Specialist on here. Perhaps he can help shed some light. Sorry about your luck and hope you can get up and running again soon!
The engine in your truck is fit for duty in a tractor, but it can be a little finicky. Shouldn't be much issue to get it all worked out.
What area are you located in? Maybe there is someone nearby that can help?
You are correct. I was thinking of @Tools R Us because he is also VERY knowledgeable, but you are correct it is @jonheld. Sorry Tools..........
I've had a feeling there was more than one issue, and there was some kind of disconnect going on. I'll keep it in mind as I move forward, try your tips and see if I can isolate it. Before I got a new battery, I would try it once, then wait like 3 minutes and it would start right up, and holding the key in the on position til it 'caught' seemed the trick. Thanks for the info, its always comforting to know its a thing and not just mine.
Just South of Houston, Texas City. I've already had the EFI relay overheat, replaced it a couple years ago. I checked all the fuses and they're good. What is the possibility it could go out again? How do I find out about local groups?
We posted at the same time. See my link above yours for local chapter. Or at the top of the forum pages there is a link for "Clubhouses". Under there would list all of the Texas Clubs. I know the Lone Star Land Cruisers group in DFW is very active because I used to live there.
The EFI relay is a fairly common issue. The EFI relay is on the drivers side about 16" from the exhaust manifold so it gets hot and won't work. You have 3-4 other relays that are the same part number in the Drivers side kick panel by your left foot. You could "borrow" one from there in a pinch and should carry an extra one in your 80 at all times. They are about $10 from the dealer. And only buy them from the dealer. They are part #90987-02004. This would only apply if you try to start you truck and you DON'T GET A CHECK ENGINE LIGHT when starting. If you are getting a CEL when trying to start then it isn't the EFI Relay. There is also an EFI Fuse in the same box under the hood as the Relay. There is a way to relocate the EFI relay in to the cab of your truck, very easy, takes about 30 minutes. You could also insulate the Fuse box or get the Camry relay that plugs in to where the existing one plugs in. I checked on this and it was $75+ for the Camry relay and didn't have the money so I just relocated my relay inside my truck. No issues since and it has been fairly hot here and would've had issues by now.
It sounds like there may be a vacuum issue as well. I had a similar issue a couple of years ago. I was able to hear the hissing sound and identify the hose fairly easily. I have since replaced all of my vacuum hoses and deleted my EGR & VSV and haven't had any issues since.
Definitely check the plugs. Take pics and post what they look like and smell like. Personally, I only buy plugs from the dealer. They come already gapped correctly and just need to be put in. Not sure where you got the plugs before but if they weren't gapped properly that would definitely effect how it runs.
Awesome info, thanks. I am getting the CEL. I don't think its the EFI relay this time, but I'll def take that advise for the future. I should be able to take another loom at my truck today, and I'll get a photo of the plugs.
If someone brought me this truck and told me it is not running, the following is what I would do, in order, to confirm where everything is so I can establish a base line. I do this with EVERY car I start because seeing something at one step can influence your decision at the net step.
1) Check the oil. It should be black or amber, not like chocolate milk. It should be at the correct level. It should NOT smell like gasoline.
2) Check the antifreeze. It should be uniformly red, or green, but NOT brown, orange, or clear like water. It should not have lumps or pasty substances. It should not look like chocolate milk.
3) Check the spark plug wires. They should be in the correct location on the distributor cap. Trace each wire to make sure the wire goes to the correct cylinder number. (Number 1 at the front of the truck, number 6 at the back.)
4) Check the rotor inside the distributor (if equipped). If it is broken, replace. If burned or arced to the point the tip is gone, replace. If scorched, but not burned off, clean the tip with emery cloth and reinstall.
5) Check the terminals inside the distributor cap. If heavily oxidized, replace it or chip off the oxidation using emery cloth and a pocket knife. Be VERY careful to not scratch the plastic of the inside of the cap.
6) Check for fuel. Does the gas gauge say it has fuel? (cannot always believe it). Is there fuel pressure in the fuel rail (or carburetor)
7) Check the voltage on the battery. It should read 12.6 Volts MINIMUM across the two posts. If it is less, then it MUST be charged or it is a bad battery.
8) Clean the battery posts and terminals
9) What does the air intake filter look like? Is it clogged, missing, have holes in it, soaked in oil? If any of these, rectify the situation.
It takes (3) things to make an engine run: Fuel, Air, and Spark.
10) Attempt to start. Crank for no more than 30 seconds with a 60 second cool down time for the starter.
If it does NOT start, I would attempt to isolate which system is failing: Fuel, Air, Electrical, Mechanical.
In this case, you have multiple possibilities and I feel you should start at the beginning. Assume NOTHING was done correctly and look at it with a fresh set of eyes and attitude. Unfortunately, you've had some folks under your hood that probably shouldn't have been!!;);)
Also pull your spark plugs as @LS1FJ40 suggested. Check the gap, post pics of what each plug looks like on the tip BEFORE you clean it. Check for proper gap. The gap is listed on an under hood sticker if I am correct. A black, wet plug indicates oil or fuel fouled. A light tan, dry plug is correct operation. A bleached white plug is running lean or possible head gasket problem. A black, dry plug indicates burning oil or running rich on fuel.
Use the paperclip method to check for codes and cross-reference the codes here.
That'll do for the short list!
Good Luck!
OH YEAH..........WELCOME TO 'MUD!!!!!!! :flipoff2::flipoff2::flipoff2:
Good Luck!
Awesome!! Thank you!!! :)
Make sure to learn how to read the CEL codes. You don't need a special tool, just a paperclip. There are also a lot of resources for free Service Manuals. Do a search on here, i think @Trollhole is the guy who posted all that.
[QUOTE="
3) Check the spark plug wires. They should be in the correct location on the distributor cap. Trace each wire to make sure the wire goes to the correct cylinder number. (Number 1 at the front of the truck, number 6 at the back.)[/QUOTE]
I would start with #3. If you have sequenced the plugs and timing wrong, all types of crazy stuff is going to happen. Plus it is what you were working on. Make sure the distributor cap and rotor are all correct as well.
