Build My Tucson 40's
The interior of the tub was already coated with something. I used Lizard Skin on the trans cover.
Could you post some pics of the inside cut lines for the liner? I’m about to do mine and I’m not sure if I want to coat the inside upper rails.
Here you go.
Alittle bit everyday.......
While trying to install the fuel door, I broke a small bolt off in a really bad spot. Remember to always run a tap thru the threads first. I ended up buying this Harbor Freight special. It's a 90* adapter for a cordless drill. Worked like a charm. Ran a tap thru and installed parts with no issues.
View attachment 2725893View attachment 2725894View attachment 2725896
Was it the Phillip heads screws that hold the lock plate/bumper?
Awesome build. Where did you source the trans tunnel gasket?
Baby steps. I pulled this brake line out and added another hoop at the bottom to make it fit better (looks weird but fits good). Then bolted it in place with the factory clamps.
Got another bunch of parts getting delivered for this weekend. I hope to get alot of loose ends finished up and start on reupholstering the seats.
