My Piggy needs a new engine
SPOKANE, WA
Website
www.waterglidermedia.com
I can only imagine how many guys ask this question...but I'll ask anyway.
My 1F is toast. I want to put something else in rather than rebuild. My mechanic is recommending a 305 with an NV4500 Tranny. It goes against my purest instincts of keeping it stock, but he has made it sound so attractive of an option.
I don't go off-road, and I want an everyday driver. Whatch you guys think? I'd rather do it right rather than save a few bucks.
Thanks in advance
Sean
1974 FJ55
Why on earth is your mechanic reccomending a 305? I'd be suspect of any mechanic reccomending that.
Secondly, what is an ND45? Do you mean NV4500? That could be a good swap.
The problem is that you'll end up spending a couple thousand dollars with your mechanic just on labor to install these, on top of the purchase prices.
I just talked to him this morning on the phone- maybe it was NV4500. I don't know much...but I am trying to educate myself. That's why I am here.
He said that the 305 was better than a 350, and got better gas mileage. Why don't you like the 305? What do you recommend other than getting a new mechanic? Also, I am fine spending money on a mechanic. I don't have the time or interest to do the work myself.
find a 2F, easy almost bolt in, stays Toyota, no adapters, same driveshaft length
have it done in a weekend. running down the road again.
find one locally being pulled/parted out should be $500-700. would give you many years of service.
I'll think about it and look around. If there was no other choice, which 2F rebuild is preferred: Specter or Man-a-Fre?
NEITHER. Find one that is used in good shape and swap it in, OR have a good engine shop rebuild it. That would be the easiest thing. Honestly if you are going to go the V8 route and are going to drive it mainly on the road, a 350 with an automatic tranny woudl be my reccomendation. Realize that it will be much more expensive going the V8 route, especially having someone do the work. If you are happy with the F engine, upgrade to a 2f and do an easy swap. I agree with the others, a 305 is pointless, there are more adapter and aftermarket for the standard 350 block and the gas mileage is not enough of a savings to really make it a consideration. Give us some more info, what is your $ budget, etc.
Noah
That was my original thought. But for the price of a rebuilt 2F from Specter, I can do a V8 conversion I think.
Paying someone to do the swap?
Do they know Land Cruisers?
One better....do they know 55's?
Whatever number you come up with for your engine, tranny, tcase adapters, drive shaft mods, etc, add 1500+ to it....you will find out why when you have 'thought of everything'.....except for this and this and this and this and this and this and this....oh, and then there is this......and this.
Done properly, a V8 swap can be very satisfying and work really well. However, if short cuts are taken, you could end up chasing one issue to solve another, only to create another.
I would try and find someone that has a V8 in their 55 and talk with them for a while.
Good luck!
-Steve
The guy's shop is called "Landcruisers Unlimited" in Rathdrum ID. He really seems to know his stuff. He has kits available for power steering ugrades, disc brake conversions, etc. He currently has a sweet 40 he is doing a complete off body restoration with custom bumpers, v8, etc.
My budget is open. But don't tell my wife.
well, if it is truly open then I would do the following based on what you want:
- custom alcan suspension swap and new shocks
- Power Steering (saginaw)
- Minitruck front discs
- Rear monte carlo discs
- Vortec 350 crate engine
- Automatic transmission
- 33 inch all terrain tires.
That would be a sweet piggy, expensive, but sweet.
Noah
PS - oh yeah, and a good lawyer for when your wife leaves you! :)
Waterglider,
I don't know much about the shop in Rathdrum, but I love the Spokane area. I grew up in Sandpoint Idaho. I don't know what your intended purpose is but i think that will ultimately drive your engine decision. If I could do it all over again, I would look for a 2F or a 4bta diesel. When I was thinking about the engine swap in my 55 I was overwhelmed with the choices. I really wanted to swap in a 1HD-T, but the long wait and the availability of parts turned me away. I was then talked into using a 2UZFE from the wife and I dreading the day I have to get it running. I would say if it is going to be a real trail truck use a simple motor that you know how to work on.
Ryan.
another option for you, if you want something a bit cheaper, this is what I am doing on my current FJ55 rebuild, keep it mostly all toyota and gives you more of a top end speed for the freeway:
- 2f engine rebuilt (fj60 dizzy, headers, jim c rebuilt carb)
- H55 5 speed tranny
- split fj60 TC and parking brake conversion
- mintitruck front discs and knuckles
- monte carlo rear discs
- minitruck power steering
- stock 4.11 gearing
may not be as exotic and powerful as the V8 but it should be a nice daily driver. I am building mine for the street mainly as well. My build is below if you want more info. Hope this helps!
Cummins diesel and an auto if I had to deal with Spokane traffic.
Cummins with a manual for everything else.
V8- been there done that. Spark plugs are for cars.
BUT, if you're deadset on a V8, I'd go with a a vortec and an H55F. Shifts nicer than a 4500, more usable gears, and bonus- split case. Otherwise I'd just put a healthy 2F in it.
Ever come over to the wet side of the mountains? I've got a low-miles-on-a-complete-rebuild 82 2F sitting in pieces in my garage that I'd like to get rid of.
Technically I sold it a guy in Idaho about 2 years ago, but he hasn't come to get it yet and I'd gladly refund his money if someone else wanted to buy it (just to get it out from under my workbench - nothing personal). It's kind of a long story on why the top end is dismantled, but the short block is complete and in great shape if you want the quick-and-easy (and all Toyota) fix for your rig. $200 if you come pick it up. I suppose I could even deliver it to Spokane for the right price.
Let me know if you're interested or want to hear the full details.
Eric
