Im still running the stock AC in my 89 and haven't had any issues with seals and I know it's still all stock.
Your gonna desmog yours? If so document well please cause I'm going to as well.
-Daniel Kent
I also need to change my exhaust temp thingy (I'm drawing a blank on the technical name) to a 4 wire denso unit.
Three wire has one ground, signal, positive.Yeah I have a LC engineering header so the O2 sensor is a lot further down the line. The 4 wire was recommended but what's the difference between a 4 and 3 wire O2 sensor? Research to follow. Also was told to adjust the valves one more time using 6 on the intake and 8 on the exhaust. If this doesn't work then it's new cam time which I don't want to do.
mine was exactly the same on my 83 fj60. I believe it happens when installed incorrectly.On a positive note I got my buddies '79 FJ40 to start on it's own (w/o starter fluid). Replaced the fuel pump, but have never heard of or seen the arm break?
Plus I need it to tow this:
Some pics of Bimini.
