my luck really ran out!
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
my luck really ran out! Pics inside
What a pisser :mad: . I had just complete the rebuild of the trans transfer case with new clutch. Well got it all back together an hr ago and took it for it's maiden voyage. Got a couple of miles before the dreadful BAM!. Got back to the house with a stream of oill following me. Looks like somehow a bolt droped into the transfercase while doing the rebuild. Totally grenaded the tranfercase.
SO
I'm not putting another one on my self and need to buy another transfer case. Who should I buy from and what should I buy?
Damit I'm so pissed. I've already yelled aat my wife. That just got me in hot water. :whoops:
Pics of the case to come tomorrow. Oh and I fixed the rear main oil leak.
Here you go. Enjoy cause I'm sure not.
Dang Marshall, that sucks the big one. I'd try urban landcrusiers, that's where JP got his engine from and traded his core in. Let me know if ya need any help. Look at it this way ya get to get a whole new one now...haha.....Not sure if David will do it or not, but you might look at goin with the 4spd tranny and 3spd transfer case. Later Man
I don't think you could successfuly weld on a T-Case since it is a Cast aluminized steel peice. I did the same thing only it was a ball from the tranny shift linkage and it broke the entire case in half. I did make it about 300 miles on the rebuild and luckily it happened one morning in the driveway.
Good luck and maybe its a sign that you need an Orion.
Pin_Head said:
Looks like just a little chunk is missing. If so, it might be easier to just weld it up.
I thought of that but my concern is what other damage it has done to the gears inside. Though it ran fine after the grenade went off I'm concerned for other damage.
Hey Marshall there is guy in Seneca that welds aluminum. Can't think if his name at the moment but would save ya a lot of money.
Seems like even if you do weld it, it going to have a big week spot where its just going to break again.
Not necessarily. It would depend on where the crack is. If welded properly, it should be just as strong. The problem is that it is hard to weld in some of the spots that it might crack and it is hard to get the metal clean enough to weld properly.
I found a guy who had a spare he was will to let go for a couple of hundred. I'll know for sure on thursday when I go pick it up. He seems very knowledgeable. I would weld and might still use it for a spare. And buy the way here are the pick of it out.
Can you see any problem? ;)
No. Look a little closer. :doh:
I should have figured that I was missing a bolt since I had to replace the original 5 for the Tranfny saver I installed. This should have been a good clue. :whoops:
The gears and bearing all look good though so I might reuse some of them on the other tranny I purchase.
Hey Marshall, I need the top and bottom plates for the transfer case. The one I got last year to put in the 60 came with out them. I would use the ones off that one, but I'm gonna have it rebuilt and put it in the 40. If you're willin to part with them let me know. Thanks, Chuck
Just an FYI any good welder can weld the alum case. And like all welds if they are good, are stronger then the material they are on.
Weld it!
Is a couple hundred for a good empty case or for a complete tcase. Seems steep but im slow. Let me know if shipping is an option from CA. If you just want the case it may cost a case of beer or maybe 2. If its a full tcase maybe a couple more. Good luck, Eric
for the whole thing.
And this is a big hole to weld. BUt I have a buddy who can do it so I will and use it as a spare. I'll post pics when I'm done.
