Spike: do you know what should the thickness of the rotors be side to side, min and max??
Page BR-15 from the 96LC FSM (or BR-24 from the 96LX FSM):
Standard thickness: 32.0mm (1.260 in.)
Minimum thickness: 30.0mm (1.181 in)
Spike: do you know what should the thickness of the rotors be side to side, min and max?? Can't find it in the FSM. I'll see if I can get that shim locally, what problems could I have by reusing it?
Wondering also, when we put the trunnion caps back on, should we put some grease on the machined surfaces where they mate up with the knuckle housing? The FSM does not mention it but seems like something should go there to help prevent corrosion??
corsair23; guess I'll have to bite the bullet and pull the birfs off the axle shafts; tell me again how you got the clip back on/in the birf?
Anyone have a thought on putting a smear of grease on the mating surfaces of the trunnion caps before putting them in the knuckle?
. With the small amount of surface corrosion I saw on the mating surfaces for the trunnion caps, the shim, and where the ABS sensor mates to the knuckle it seems that a bit of water does get in between them. You'd think Toyota would spec something to be put there, but then that might affect preload?? I also noticed that the surfaces are left with a rough grind, maybe that helps seal them when they're torqued down??You'd think Toyota would spec something to be put there, but then that might affect preload?? I also noticed that the surfaces are left with a rough grind, maybe that helps seal them when they're torqued down??
It is because Toyota doesn't think it is important. Now quit obsessing about polishing and shining everything and get the job done. I would reuse the shim after cleaning it and filing off any burrs. This isn't a nuclear reactor; it is a knuckle job.
If that shim is dimpled- as it looks in the pic- I wouldn't use it because it probably won't compress fully when the bolts are tightened. I'd be worried about it compressing further down the line and the tension coming off the bolts. But that's just me. I have to agree with the polishing though- who are you trying to impress?![]()
Got a couple of hours to work on the front end; now having trouble getting the birf off the axle shaft, how hard/high do you drop it from, or any other ways to pull them apart? I've got a 3 foot length of 2 1/2 inch PVC, stuffed a rag in the end and set it on a piece of wood but it just bounces.
tried the FSM method with a hammer and brass bar, no go.
corsair: now I recall that in the FSM, guess you just wack in on the star? When you did yours, you dropped the axle/birf with the pipe on the floor? I've tried it a few times from a foot high, all I'm getting is the PVC pipe getting chewed up by the star and cage.
Edit: tried the FSM method with a hammer and brass bar, no go. Tried the PVC pipe method a few more times dropping it from 1-2 feet, only got tiny shards of PVC all over. This just doesn't want to come off so maybe better to leave it well stuck?? I've cleaned the birf bell out using a couple cans of carb cleaner and some degreaser, probably got 99.9% of the grease out (most was soup anyways) as it now is hard to turn.
... Tried the PVC pipe method a few more times dropping it from 1-2 feet, only got tiny shards of PVC all over.
