- Thread starter
- #301
What would make the A440F overheat? Trans has fresh clean Amsoil Dex-III, there is no slipping, trans does shift smooth, everything seems good. But the trans doesn't like to go 65-75mph for a good distance on the interstate. Soemtimes about 50-60 miles the AT Temp light will come on and you could fry an egg on the tranny case. If you let it idle the light goes off in a few minutes.
Truck has 33x10.5 tires and didn't have a Tranny cooler installed like most I've seen. I do have a factory cooler which I'm going to install, but does this really make that much of a difference?
What else should I look into as to why it doesn't like higher speeds for distance?
