Nice fab/metal work..following.
Very true, the heat is gone nearly as fast as it's made but it has provided a little relief so far. I actually just installed it two weeks ago so it's a new addition this year since I'll have a good reason to be out there. I own 17 acres, 10 of which are wooded so there isn't a shortage of wood (yet) so I've kept it stocked up and it does create a good heat radius. If nothing else it's a good spot to warm up!
I'd really like to get ride of the whole motor/trans/tcase in one piece, too bad your on the other side of the country! If I can't find someone to take it complete in the coming months I'll get back to you and the other two who've hit me up for parts. Thanks for looking.
Simple and clean always stays in style. What kind of EFI are u using?
What front link set up are you going to use
3 or triangled 4 link ?
One thing I do. For setting up. My links is use pcv pipe or cheap erw tube to make temp links
Erw is nice because you can tack it to your joints and cycle the suspension
I found on mine I had to lengthen my uppers a inch
To cure a pinion angle change as Susp traveled
Would have sucked as the heavy wall Dom is stupidly exspensive here
Yes I did use a link calculator unfortunately it didn't calculate pinion angle change I have almost zero roll steer think it was .6 deg the length change in the uppers made the pinion angle remain pointed directly at transfer case output through travel yes I could have adjusted it with the joints . But I like to keep as much of the joint threads in the link
