Most newer vehicles don’t have water channels. They just rely on the weatherstripping keeping the water out. Not always 100%, but does a good enough job 99% of the time.
Yeah but they typically have some form of rain gutter just inboard of the roof edge and triple seals in the door jamb, not much hope for that level of seal with our doors.Most newer vehicles don’t have water channels. They just rely on the weatherstripping keeping the water out. Not always 100%, but does a good enough job 99% of the time.
...enjoy the shaved look...
I like it SMOOOTTTHHHHH!! Or Brazilian![]()
Do you have the weatherstrip on the doors and the door jam?I get a lot of leaking through the doors when it rains.
In my eyes the best easiest fix would be to replace all the door weatherstrip and adjust your doors/window frames properly to keep the wind and rain out.
Go to the ace hardware extruded Metal section. Get 1/2” ply edge metal. You will be able to bend it to fit the slight sexy curves of you beautiful mistress. Using 5 or 6 pop rivets or sheet metal screws attach to the correct location at the same time bedding it in white auto body seam sealer. Seam sealer caulking is water clean up as you go. Scary part, may be to much bondo and not enough metal for fasteners to grab. Right Stuff is a very good adhesive, might be able to glue the extrusion on. (With temporary duct tape)
If you pre painted or powder coated it to match the white it could possibly look decent.
View attachment 2245160View attachment 2245161
No matter what you do, with a Brazilian there’s alway going to be a certain amount of bedding, caulking and screwing, but for sure a certain something is going to get wet somewhere.
I do have new weatherstripping but the tops of the doors and the roof line have. significant gap and are not all that well aligned.Do you have the weatherstrip on the doors and the door jam?
