Multi-nozzle injectors...upgrade?
Humboldt, CA
It atomizes the fuel better. On stock engine control it is kind of a moot point.
Why would better atomization be moot on stock engine management? Seems like that would be a bonus regardless.
Because the narrow band O2's are really just getting your fueling close enough there is no precise control over injector pulse width.
because the stock system runs rich as can be. it basically just sprays way too much fuel. i have seen on the 1FZ turbo FB group where some people have dones the stand alone first, getting ready for turbo, and picked up power and about 10% better milage just from the ECU changes.
I figured that was true, also, because most other older Toyota EFI systems do run super rich. But, I installed an additional bung in the upper exhaust and installed a wideband to investigate. AFR's never faltered from mid 15's unless you really got on the throttle hard enough to send it into closed loop (I assume).
I've got a set of 23250-70080 denso injectors if you want to try it. These are an identical fit for our stock injector, 4 hole and rated at 312cc.
EDIT: sold, left for information purposes only.
What’s the method for leaning it out a little? My cruiser just stinks of fuel in the exhaust
You use to be able to open the air flow meter and turn the gear inside to adjust our afr's. That's for obd1 at least. On obd2 you usually have to change the parameters in the computer itself. Since the obd2 cruiser use what I believe is a air flow meter you may be able to adjust the afr's without going into the computer. You really need a wideband to make sure you get it right though.
On a side note I thought the obd2 cruisers had wideband o2 sensors since they are 4 wire and have a much broader range of sweep?
I swear when I had a scan tool hooked up it showed me my afr's and that's how I found out my one o2 sensor had a fault that turned out to be a bad heater wire.
MFG Brand Name DENSO
MFG Name DENSO
Heated Yes
Market Availability Date 2010-01-01
Wiring Harness Overall Length (in)18.5
Oxygen Sensor Type Narrow-Band
Internal Supplier Part #13095
MFG Model # (Series)234-4153
MFG Part # (OEM)234-4153
Supplier Company Name DENSO
Product Name Oxygen Sensor
Nope, OBDII is narrow band O2s and no AFR, it uses a MAF not adjustable.
Not true, you can basically bypass the MAF slightly by running a tube AROUND the MAF. You drill a hole in the air filter box, insert and RTV a piece of heater hose in (I suggest 5/8" for about 10% improvement) and then just drill a hole in your throttle body and RTV the other end in there.
That way you're always getting about 10% extra air for the amount of fuel your engine wants to use, but it's sneaking past that pesky MAF
Haha yes you can add a bigger MAF housing, you can use a voltage modulator, you could add some kind of bypass tube, but it is not adjustable.
And even if you do that, the ECU increases injector pulse width because the O2's are reading lean.
That is the whole point of closed loop.
Well, that's where you're especially wrong. In that bypass tube I mentioned - that's where you're supposed to run a 7th injector that you control yourself from within the cab with a momentary switch. You can just add that fuel right back in if you want to avoid leaning it out. Honestly for someone who knows as much about turbos as you, you'd think you'd have already done this
No I prefer to do things right.
