I also just found that there is black oil coming from the exhaust part of my turbo.
Going to be hard to make much boost without load, hold off until you get it driving to worry about how much boost you can or cant make.The gauge I have says it’s below 1 psi. I’ve checked the parameters on the edge CTS and they seem to be what they are supposed to be.
I believe right around 800 RPM is normal.It’s saying 1500 rpm at idle. Is that a normal idle?
What size drain line are you running for your turbo?
3/4" rubber with barbed fittings? If yes whats the ID of your fittings?The drain line is 3/4”
I believe Holset calls for a 19mm minimum drain size, most of the ¾” fittings I seen had a 5/8” or 16mm ID on the fitting itself. This caused my turbo to pump oil past the seals when I first switched from the BW turbo to the Holset.
What are you counting, the flats of the nut or some sort of wheel with teeth?This is where my rpm is read from.
The Mechanical Tach drive mounts on the timing case cover and connects with the Injection Pump Shaft for drive power.
Guess I’m confused then.
You are using a mechanical tach drive to drive an electric tach without an interface?
I just assumed I would only need the tach converter.
FYI, I used the DSL-2E Universal Flywheel Tachometer Interface and it screwed right into the back of Cummins trans plate.Haha. Clear as mud
They said if I couldn't figure it out to use another source for tach signal.
I read quite a few people say to drill out the restrictor to allow for more oil
