Metal OEM Toyota New Oil Filter Housing Cap + Plug
Evanston Wyoming
Website
www.badlandsexpeditions.wordpress.com
Is this a worthwhile upgrade? I guess the stock oil filter housing is plastic.
Genuine OEM Toyota New Oil Filter Housing Cap + Plug 15620-31060 15643-31050
Amazon product ASIN B07984MX2G
Totally worth while. Regular toyota filter wrench fits, less likely to break, can still use the drain tool etc.
Heads up though.. I ordered the correct venza part through my local online parts page, and they automatically changed the number to the correct plastic one for my landcruiser because that's the VIN I entered. Make sure it's actually the aluminum one before you leave if you don't have it delivered.
Yes definitely worth it. I just changed my oil and added this and the TRD filter. My local dealer Stevinson Toyota West and bought both together for $40 plus tax. Check them out online - great prices and service.
Curious, in what vehicle?
Looks like I'll order one. I like the idea of the Fumoto drain especially since I have an ARB skid plate. It would be nice to be able to direct the ild away from the plate.
I suggest you go ahead and get the bjowett part. After you screw around with the Filter oil drain release a couple times you’ll wish you had.
i bought this, and then the $30 brass two way release with hose. It’s ok, but the other part is only $20 Moore and it solves all the problems.
You still have to remove the plate to change the filter. Even so the setup is easier to drain it. I cut a hole in my ARB skid so I wouldnt have to remove it, with a bolter plate covering it
I have since swapped to the Slee skid plate which has a removable panel so you don't have to remove the skid
I don't know why people make a big deal about the stock filter drain process. As long as you put the o-ring onto the tool before inserting into the filter cap and press it in firmly and quickly, you will have no leakage or mess, no issues. A 5yr old could do it.
It can be messy for sure, but not a huge deal, as long as the plastic thing stays in place. I guess I need to locate a 5 yr old service tech - lol.
I had one of the "ears" snap off the stock plastic housing leading to an upgrade to the Venza housing, and later the BJowett. Buying a specialty filter removal tool makes all the difference.
Here are the two I bought:
The BMS one is a work of art.
I have the BJowett housing and wil never use them. Pm me an offer if you are interested.
