I have that. It works very well.This is also interesting: Oil Filter Drain Tool for Toyota, Lexus, Scion 2.0L - 5.7L Engines
I've had some good luck with Motivx tools.
I would think the plastic would be a better material for threading and un-threading for the housing , 2 similar materials could cross thread ?
Does the Aluminum need a longer center tube ? I rememeber reading it could need a longer tube swapped out .
Have you used any lube on the aluminum threads like a antI seize ?
Will 15620-31060 15643-31050 fit all 5.7 to 2020 ?
Maybe a little of thread ....
Has anyone done a remote located filter like Baxter Performance offers a filter setup ?
I got spoiled with my oil Tacoma 4.0 was the best And easiest filter ever .
This is my plan on my new to me 2018, when I need to change the oil. I’m planning on doing my own service.Or you can go full monty and get bjowett's fancy filter housing with the built in Fumoto valve for easier drainage:
Jowett Performance Filter Housing with Fumoto drain valve
forum.ih8mud.com
Same for me.Hey guys - I just changed my oil and put in the trd filter. It definitely is loose and slightly longer than the oem filter in the housing. Is this an issue? was it the same for you guys? Thanks!
I just ordered the full Jowett set up. I also ordered two trd filters and two oil drain plug gaskets. I have two dumb questions. 1) do I use the oil drain plug gaskets with the ez drain oil pan valve from jowett or do I just install the ez drain oil pan valve directly using proper torque? 2) do I have to buy a Toyota filter housing removal tool to get the OEM filter housing off?The TRD filter works correctly in the BJowett filter housing.
Thanks Charlie! Appreciate your help. I will look into that before I buy one. Might be able to rent one from autozone or oreilly also. Take care!I didn't use a Toyota gasket on the Fumoto valve. I think it comes with an o-ring on it, but I don't recall for sure. I doesn't drip or leak though. Yes, ideally you'd have the Toyota factory style filter wrench to remove the factory filter housing. The Jowett filter doesn't use the factory filter tool, it has it's own very large socket (available from BJowett or on Amazon if he's out of stock). Since you're only using it once and then replacing it with the Jowett, it sure seems wasteful to buy one for one time use. I wish you were nearby, I'd just lend you one of mine. Is there anyone on here or a local 4x4 club from your area that would loan you the factory style filter wrench for a one time use?
