Finally fitted then?
Can you tell me what your minimum rpm is to get 10psi? How does spool compare to the CT26 and which turbine A/R did you get?
*edit*
BTW the 65mm mentioned earlier is the compressor inlet. To put that into perspective your GT2871 in 56 trim has a 53mm inlet.
ok got the .64 hot side and i will go for a drive toomorrow and let you know. what gear or road speed did you want to know it will make 10psi. any thing else you want to know just let me know.
