Great to hear from you. Unforrtunalty no numbers. Some experiences though....
I first increased boost to just before boost cut (HKS EVC3). ECU definately provided more fuel so that was good. Still need to look at inlet air temp sensor to see what effect adjusting the vaules does....
I then fitted a aftermarket programmable chip and blew out the drive clutch in the transmission. This was while towing a 4t caravan through sand at 20km/h. anyway the trans is strong enough but the chips dont work well with the factory computer controlled shift changes (delays in clutch engagement = lots of slip).
I was 800km from home too. Still, 1st-3rd worked so I dumped the oil, kept flushing (bought 15L!!) until clean and drove home in 3rd at 3500+rpm LOL
So, got home a few weeks ago, pulled the 5spd auto out, mildly stripped it down, changed the steel and fibres on the direct clutch (the fibres were down to the steel....) put back in (total 12hrs, not bad methinks) and it ran sweet.
I had bought a shift kit for the trans and finally fit that (man I wish I did that while the trans was out crap messy job, but not having built a trans before I wanted to split the work I did into stages...). Now it shifts like a beauty - very hard, very firm when needed. I am still considering aftermarket programmable oprtions though. I would also be suprised if the box could handle more than 800nm - small shafts (big clutches though).
To give an idea of torque with Chip, our hills down south WA are not so steep, but through undulating country, fully laden and probbaly towing 4t I could hold 5th locked up on the TC up 90% of the inclines at ~ 90km/h. Without the chip wouldnt do it in 4th, not a chance. My tuning regime was keep increasing until it could hold 5th locked up up fair inclines - I am a cowboy.
I had the chip set to alot higher than reccomended but NO SMOKE and the oil was almost petrol clean after 800km of this driving (got more dirty coming home at 3500-4000 though).
Last night I did a fuel economy run, mostly freeway and 90-95km/H and did 7.8L/100k or 13.05km/L. I was shocked.
Will be setting up all the gauges and stuff soon, but want to get the thing pitted first.
I have almost completed the turbo build to replace the excellent stocker (great turbo on these). anyway, should be impressive and will post details soon enough.
Good to see you back Graeme. How's the data collection on the diesel lexus going?
Speaking of scary A/F's. Some of the remap tuners in the UK think 13:1 is a good thing on a diesel.
