LX450 Climate Control inoperable
Air Capital of the World! Wichita, Ks/Choctaw, Ok
I recently purchased this at an auction, it has 203K miles and is in decent condition, however the Auto HVAC doesn't work. First thing I noticed under the hood, there is a red wire coming from the firewall that is spliced into the A/C compressor and there is a switch on the dash to turn the compressor on and off. Well, that seemed to work sort of but I wasn't happy with that so I figured I'd purchase a new climate control module off of ebay. When installing the new module I noticed some wires were cut on the wire terminals that plug into the module. I temporarily reconnected the wires and cut off the red wire that runs to the A/C compressor. Problems solved I said to myself, not exactly! It seems nothing works, no fan, no defrost, no nothing....so I put the old unit back in, still nothing. I checked the fuse, it's good. I've read through the other posts dealing with this sort of issue but was unable find anything this specific. Hoping to get it fixed. Crappy pics but you can see that the large red wire was added and some point and then the wires that the yellow (splice) wire were cut and just left open. Just looking for some help and direction....Thanks Mike
there is a white box under the dash that controls the auto function, its called the AC Amp. 88560-20211, 88560-20212 or 88650-20210 should be the part number. not 100% sure which one of those numbers it is but its mounted about shin high above the gas pedal on the right.
first I think you'll have to find out why they butchered up the wiring so badly...
I'll check it out once it warms back up.
I pulled the controller, seems normal with no corrosion like I've seen on others but it has this little wire soldiered on to it. I don't remember seeing that in other posts.
The wire does the same thing as the trace it seems.
so it's probably ok? I'm thinking I need a list of all parts and just start replacing them....
Mine is suddenly inop as well, @85badger
I blame you.
:flipoff2:
I blame you.
:flipoff2:
So anyway, my system randomly stopped working last summer. I removed that same module and cleaned the crap out of it: baking soda, IPA (for me, Isopropyl alcohol for the circuit board) and it worked. Lately, my truck has been sitting/driving in nearly constant rain for like two weeks. Most likely related. It might F* up my skiboarding plans this weekend...
:crybaby:
:crybaby:
I finally got it into the garage tonight. Had to dry out a lot of camping equipment over the last few days...
Mine stopped working this last week. I blame you too. I'm thinking I might just replace the LX controls with the controls from my LC.
typically, when people splice into the A/C wiring, they hook up an auxiliary fan that comes on when the A/C compressor runs, with the overall aim to keep the engine bay cooler
just a comment, not idea whether this applies here
I have a spare LC controller, but it didn't work either. There are a lot more wires on the LX version....Has anyone successfully done that swap?
I would take everything back to stock and then go from there. Remove all the PO wiring mods and sauter new wire to bring back to stock. It could be possible that a connection in this added wring is not working.
That's what I'm thinking about doing. Remove all tampered with stuff to get a good baseline then start replacing parts.
The Lexus FSM has an excellent AC troubleshooting guide, but it will be hard to take advantage of it with the wiring hacked.
If the point of the wiring hack was to manually operate the AC clutch, maybe the doofus did it to bypass one of the cut out switches that prevent the system from over or under pressure situations.
I need to get ahold of that portion of the FSM. For mine, I think that once it dries out it will work again...
< edit: found a copy of the manual on my drive. :doh: >
