LX 450 Needs Help in Canada!
Hello, my cruiser friends. I am in need of some advice. I just drove from my LX450 from Colorado to Central America and then up to Canada (8500 miles total). The trip had been flawless until a few days ago. I pulled into a small town in the Canadian Rockies and within 10 minutes the LX began studdering as though it wasn't recieving fuel properly. I made a few laps around town looking for a garage before it finally sputtered on an uphill and died. It wouldn't restart so I rolled it to a parking spot and walked to a hotel.
The next day I replaced the fuel filter and she still wouldn't start. I turned her over a good 25 times before I gave up and called the tow truck. The old filter wasn't completely clogged but was very difficult to blow through. I found a garage and 2 days and $370 later had her back. The told me that a wire deep within a wiring harness below the battery had shorted out. The wire was providing power to the ignition and the fuel pump. They showed me the small white wire and it had a small nic in it and was clearly burnt and damaged.
A few hours later...
I'm driving around for a few hours and everything is fine. Then I pull off the highway and when I accelerate to leave the pullout she starts sputtering again. It's been happening for a few days now only at low speeds when I stop and start again. It only seems to do it below 2200 RPM and then it clears up. It feels as thought it's a fuel problem to me. The mechanic suggested it may be an oxygen sensor malfunction. What's a guy to do? ANY ADVICE WE BE GREATLY APPRECIATED.
I have tools and a service manual with me. My wife is 6 month pregnant and I have a 14 year old dog, so breaking down again isn't really an option. Thanks :confused:
the problem sounds like the fuel pump relay. The contacts on the NC side get pitted and the pump doesn't run at full speed. I did a writeup on this a while ago and can't seem to find it.
There was another one done but the author suggests sand paper to clean the contacts. I would not use sand paper ever! A much more appropriate cleaning material is the striker from an un-used book of matches.
The relay is located in the right side fender well just behind the fuse box on theat fender. It is held in with a screw and is actually inside the fender itself. Once you get it out the cover can be pryed off and the contacts to be cleaned are inside.
Best Of luck
Side note (landtank's advice is excellent): You went 8500 miles with a pregnant wife and an ancient dog? You have some stones son!
Thank you very much for the advice. I took the fuel pump relay off and sure enough it was heavily pitted. I filed it with the match book and tried it again to no avail. I then repeated this step 3-4 times until the pitts were almost completely filed away. I was careful no to bend the contacts. Still with the pits almost completely gone I am still experiencing the same problems. It was interesting to note that each time I filed and reinstalled the relay the problem seemed to happen at slightly different RPMs. I think it may just need to be replaced. ANY THING ELSE I SHOULD TRY BEFORE GOING BACK TO THE MECHANIC OR ORDERING A RELAY?
AS I SAID BEFORE ALL ADVICE IS VERY MUCH APPRECIATED.
Also I'd like to personally than DanKunz for his generous comment about my stones.
Isn't there a method to run a jumper wire in place of the relay? I can't remember where I saw it off hand tho......
Update
So this morning I went for drive up a trail to see if she had miraculously fixed herself over night. Everything was looking great, the problem didn't seem to be as bad. I was heading up a trail and decided to put it in Low. As soon as I shifted into Low and accelerated the truck started lunging forward 2-3 times and then died. As you can imagine it wouldn't restart. So I rolled her back down to town and am now contemplating calling the tow truck. It basically seems like it did what it did the first time it broke down. I'm going back the mechanic that charged me $300 to fix it the first time, maybe he'll get it right this time.
THANKS TO EVERYONE WHO REPLIED WITH HELP. I APPRECIATED IT AND SHALL RETURN THE FAVOR SHOULD I BE ABLE.
I'll post a follow up of the fix when it's done.
I have had bad spark plug wires act kind of similar, rough idle/low speed, then ok at speed, when I tested them, they seemd ok, but the problem remained, with new wires the problem was gone. If they are original wires (10-11yrs old), they could use replacing anyway. The OEM wires actually have the date stamped on 'em.
If you can give a more precise location a local cruiserhead may be close enough to come out with tools and their spare parts stash or recommend a local shop that may be able to help.
First area to check (as Lanktank pointed out) is the main engine harness by the EGR valve. (Lots of specific advice and troubleshooting tips here on 'Mud in the 80-Section.
Next area to check is the ribbed intake tube that goes between the air filter canister and the intake. You're looking for air leaks; specifically cracks in the bellows section that usually are seen on the underside of the tube.
Good Luck and keep us posted.
-B-
Update - Problem Fixed!
IH8MUD = 1 MECHANICS = 0
After another tow and a replacement fuseable link. I got the car back still shuddering during acceleration. The mechanic suggested that it may be a transmission problem, a torque converter or a drivetrain problem. It didn't feel right to me so I went a spoke with a Toyota Dealership and another small mechanic. No one really had a clue what was actually wrong. I set up a diagnostic appointment for next week at $85 an hour and drove back to my motel.
Thanks to the advice of the IH8MUD community I finally found the problem! The Main Engine Harness mount had broken and it was lying on the EGR pipe, which had deteriorated the heat tape. I opened it up and found that 2 wires had melted together and were shorting out.
I striped it clean, fixed the wires, rewrapped it with heat tape and zip tied the harness away from the pipe. Problem solved!!! THANK YOU IH8MUD COMMUNITY! We outsmarted 2 mechanics and a Toyota dealership.
I found this post to be incredibly helpful: https://forum.ih8mud.com/showthread.php?t=147091&highlight=main+engine+harness
THANK YOU :cheers:
Glad you got it taken care of! Mud is great!
I didnt know about the silver star until after a few weeks of being on MUD. I saw a post suggesting the purchase to someone with a relatively high post count asking for help. I went looking for Silver Star info and purchased mine immediately. There is a lot of information to absorb and the Silver Star Supporters thread is easy to bypass. A friendly suggestion after receiving some good help seems reasonable to me. If you want to see, obnoxious, try Classmates.com. there was a pop-up that comes up on just about every click asking you to give them $$$$.
Glad you got it fixed. This site has saved my butt a few times.
It is the policy of IH8MUD not to pressure you to buy a star unlike other sites that you can't even do a search without a star.
I deleted the debate (Sorry guys) because it did not add value to the thread. It's OK to let someone know about the star. Debates on who should buy one and why are best left to chat.
