Looking to get my engine rebuilt.....
The Woodlands
Please point me in the right direction.
I want to find a good mechanic to rebuild my engine, currently living n Houston area but willing to trade 200 miles for a good one.
What should I expect to pay for such a job?
Tia
G'
Cant help wth TX referrals but hop on the local TX clubhouse and post up for more local exposure.
Id budget 3-5k but thats an open ended question. What all else are you gonna tackle while in there? Short block is still avail new btw at around 4k.
For sure I'd check with Duc at Duggy's Garage, jsut down from you off 45..... great guy and excellent service, plus he's straight up on what you need. I'm going to be doing a HG as PM soon, and he'll be doing it.....
E
I wonder what te time frame would be to rebuild one...
How many of you would rebuild the straight 6 vs swapping it to a V8 ?
I did.
If one was set up to fully do it themselves with enough time and an adequate garage, doing a V8 or even a 6BT swap makes sense. If you have to hire much of it done? Becomes a different equation.
Might already be posted some where in the forum, but how many parts/changes are involved with swaping from a 1994 LC engine to a newer 95 and up w/OBD II.
So what's wrong with your current motor? We have done a bunch of head gasket jobs and head rebuilds, and most all of them had a great solid lower end. No work required on the block. pistons, crank, etc.Most of these were well over 200,000 miles/
My mechanic buddy is rebuilding my 1FZ, and even though it has 280,000, the lower end looks like it has 10,000 miles on it. We’re just honing the bores and going back with standard everything since he’s got it all apart. The bore mic picked up less than half a thou variation.....if the PO hadn’t overheated it at some point, we wouldn’t be doing anything!
BTW, my buddy isn’t exactly a Toyota fanboy, and even he was amazed with the quality of this motor.
To answer your question, I love my rig and plan on keeping it a long time.
Was planning of adding a rear locker and maybe a small lift.
Right now the power steering pump is leaking bad as well as the main seal, I figured it just needs to be all redone.
G'
