I tow a 3500 lb. trailer 5K miles or so per year. Anyone out there with long term towing experience noticing any damage from it? And what's the best way to maintain the LC along the way beyond the factory maintenance schedule.
I've towed probably 3,000 miles this year at weights between 2,000 and 6,000 lbs (and ironically over the pass through Bend). Other than fuel, the truck really doesn't care much. Just common sense things like use manual gear selection to keep it from hunting and to keep the TC locked as much as possible to minimize heat buildup. I would also recommend that, if you're over 60k you do a full fluid exchange on the transmission.
Also note that the owner's manual requires trailer brakes for over 1,000 lbs, sway control for over 2,000 lbs, two axles for over 3,000 lbs, and load distribution hitch for over 5,000 lbs. I've violated all of these with no ill effects, just mentioning for awareness. The one rule you should never violate, though, is proper tongue weight. When in doubt, keep it forward.
" to keep the TC locked as much as possible to minimize heat buildup" What are you referring to as the TC? The only TC I'm familiar with is the Transfer case.
I shouldn't have abbreviated. Torque Converter. It can either be mechanically locked or hydraulically driven. When locked there isn't excess heat buildup from within the Torque Converter. Better to shift down to 4 or 3 and keep it locked then let it slip in a higher gear. If you have an OBD app on your phone you can watch the trans temps climb.
If you keep it in a lower gear you will also stay locked up. So with the 6speed its recommended to use 4th as final gear and 6th for 8speed.Thanks , now that brings the question how to lock the TC ? The only way I've seen that is having an Australian valve body kit installed $$$.
I don't tow too often so only providing what I've learned here
OK that makes sense. I've driven down hill without a trailer and have manually downshifted to 2nd. Doesn't really slow down the truck like a manual transmission.
This looks like an upgrade for a later date.
Wholesale Automatic Transmissions -
cruiserbrothers.com
Same here. I've got over 40,000 miles on my 3 year old truck, almost all towing. The LC is built for it and I don't think will have any particular concerns for wear if maintained well. I use the severe service (towing) recommendations in the owner's manual, including extra gear oil and engine oil changes. I also use airbags in the rear springs that likely help longevity of the shocks and bushings. Oh, and I also make sure the propeller shafts are lubed every year.I tow a 3500 lb. trailer 5K miles or so per year. Anyone out there with long term towing experience noticing any damage from it? And what's the best way to maintain the LC along the way beyond the factory maintenance schedule.
Will the TC lock up in lower gears? If I remember correctly, the 80 series would only lock up in the two highest gears (3&4?), but I could be wrong. Not sure on the 200.
To add to the TC lockup info, some people might be concerned with having the RPMs elevated for extended periods on the freeway. Keeping it in a lower gear to keep the TC locked might require driving along at 3k or 3500.. There is nothing wrong with this. If anything it does a better job of keeping oil pressure up, coolant moving through the engine, the fan spinning, etc. And, having the TC locked up is MUCH better for ATF temps and as a result transmission health.
I have a Lance trailer, it has brakes,I have a brake controller in the LC , I carry a spare tire, tires are new and axel is greased and I use a WDH.* Does your trailer have brakes? If really does help keep wear on the truck down if your trailer has brakes.
* If you're in an LX your AHC takes care of leveling. If you're in an LC you may want air bags depending on how you l load the trailer and where the weight is.
* With only 3500 lbs the weight isn't that big of a concern, but personally I run different oil if I'm towing anything over 5000 lbs more than once. I prefer Mobil1 0w40 european formula or Castrol 0w40 european formula.
* Apart from that, make sure you always carry a spare tire for the trailer, and make sure your trailer tires are not over 5yrs old. And keep the trailer axles greased and serviced.
