I had one of those tanks in a parts rig. check the bolts going through the cargo area floor, as they had started to tear the sheetmetal a bit...
Or stress load the welded seams?I like the 30Gal tank idea, and the skid plate idea, but I'm concened about the integrated skid plate and tank. If the skid plate flexes at all on impact, couldn't that ruin the integrity of the tank?
You'll notice the two straps under the tank, that come up the sides and bolt into the factory holes . These straps are 1/4 thick stock.
Lou
fighting the POs decision to block off all the vents and leaving only the gas 2inch fill hose and the carb feed line creation a very
but to runn the outlet line from it??....PO also replaced the toy carb with a weber so no return to carb line left
seems to be working well and the gas smell is not overpowering as it was + no more spillage
