If I can source a TRD rear 3rd, will the e-locker fit the existing 3rd I have, or will the 3rd completely replace the 3rd I have in an 86 vehicle? Or an 85?
An 8" diff is an 8" diff is an 8" diff... They can ALL be interchanged... But the E diff requires modding a non-TRD housing to fit.
paroose... But notice the gasket. You will need to cut a small tab out, and install 2 or 3 studs into a non TRD housing.
http://www.inchwormgear.com/store/index.php?cPath=25_62
Can you use a rear diff up front, or vice versa? And what is involved.
Yes, and zero. But as stated before a HP in the rear is not a good idea, though some hard core guys do it... But they understand the risks.
HP = High Pinion = Reverse Rotation... All the same thing.
I was following a thread way back when on an oz site, where a guy grabbed a rear diff from a cressida, and swapped it onto the front of his IFS 4runner to make a center diff'd IFS rig that was close to indestructible. Way cool, and it got me wondering.
Spruce
Man you need to get some terminology... A center diff is the a.k.a for an AWD transfer case. As in, "The FJ80 has a center diff" b/c that's exactly what it is, a differential that allows it to be operated on hard surfaces without bind.
Full Time 4WD and Permanent 4WD = AWD. AWD DOES NOT = 4WD They are a play on words, like "The wheel that slips, is the wheel that grips" Bolt a differential on the back of a transmission and that's what you'll have, a center diff.
Part Time 4WD = Only 4WD in high or low range with the hubs locked. And not advisable to use on hard surfaces. It's more like the PTO on a tractor. Pull the lever and no compromise power comes on the shaft.
MUST SEE 3:00 mark!
http://www.youtube.com/watch?v=l5u_5kzdEWA
It's only when you lock the center diff, you get true 4WD... You WILL hear Brits say "diff locks" but they mean it in a AWD locking the center diff term, not a locking
front or
rear differential/ axle term.
Diff, pumpkin, axle, 3rd, differential, all the same thing.
The Cressida(?) has a limited slip that the front carrier of the IFS front only trucks use... It's just a cheap mod to get a clutch pack limited slip. It's not a center diff, and it's not a locker. IFS front axles are the 7.5" the 2WD Toyota rears use. Zero can be interchanged with the 8".
A limited slip is NOT a locker. Any traction device that needs wheel spin in order to work is not a locker.
A traction device that does not need wheel spin to work IS a locker.
A traction device that does need wheel spin in order to work IS a limited slip.
Locker, locking diff, the same thing.
Or vice versa b/c it's a part time 4WD anyway...
Optional, but b/c you will use the rear diff 100% of the time, the front ONLY IN 4WD.
You don't lock an AWD front b/c it will make steering harder both on and off road, though some hardcore guys do it... But they understand the risks.
But you should only be where in 4WD? On soft(er) surfaces...
