Hi guys!
Lurking around here for a long while while deciding to go the LC100 route and pulled the trigger sometime in May on a 2003 1HD-FTE
amazon spec LC100.
Have multiple things going on with the car ,small updates and gremlins sorted. Will be discussing that in other relevant threads.
As far as the navigation upgrade goes, got a android 6.0 HU of
aliexpress 2GB Ram Android 6.01 10.2inch Car DVD Gps For Toyota LandCruiser 100 Lexus LX470 Car Head Unit Stereo Radio Navigation Audio 4G-in Car Multimedia Player from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group.
By the looks of it its the Seicane units(or cavanie, they both look essentially similar)So did have a lot of troubleshooting to get done
Special shout out to watercruiser for his great writeup and thts what convinced me to take the plunge
Some feedback on the major issues being discussed here:
- right of the bat, the housing sent with the HU for transplanting the circuitory was incorrect. Though specifically mentioned the model of the car, it came back wrong, and had to cut up a lot of the housing to accomodate. The mojnting points for screws were also in the wrong place so had to 1redo that too
- This version and the hardware overall is pretty stable. Yes the aluminium bezel runs hot to start but it kinda goes away after a bit
- The screen is pretty responsive , doesnt have glare issues . Overall the thing is good as in apps dont crash etc
- The tape function doesnt work after the install, and the button acts as a shortcut to toggle between the android functions and the pre android setup
- the auto reverse camera is working . Required a good amount of faith whilst splicing into a wire which was marked as reverse but based on the configuration and wiring at the back . It didnt switch automatically on selecting reverse gear at first ( i believe there is another wire tht could work out this function but couldnt figure it out) so v hooked it up to the reverse light connection to get power.
- had issues initially on the aircon selection, specifically how to select the desired temperature. turns out it can be done with the AC button switched off. Works that way and also the outside temperature ping is working perfectly
-the range and fuel consumption screen does not get any info. Havent been able to work it out so far
- front cam connected and selected through aux . Works well
- steering controls work well right off the bat. No issues
- there was no bluetooth toggle for connecting an OBD2 connector etc ( no issue with the phone as a seperate app which is used to sync up with phone works flawlessly, and you ping the HU with the phone connection) however this issue gets resolved if a 3rd part app for bluetooth toggle is downloaded
- the 3.5mm solution for the sound output is rudimentary at best. Sound quality is not all that great, and currently not at par with the sound produced via the cd changer. Also the equalizer doesnt help with the subwoofer control. There are two sets of equalisers ,one works...and the balance controls are hit & miss. The non android setup equalizer still works though. This overall is something i need to work out and still need to setup properly
Major gripes:
- its a nuisance when you are in android mode, enjoying music and feel like tinkering with the air conditioning. That abruptly cuts off the music, and takes you to whatever the pre android HU was last playing, radio or cd etc.....feels very jarring and destroys the experience
- you cant use navigation /google maps AND radio/cd simaltenously. Cd no issue but radio yeah well , tht could be better
Thanks for all the help on these forums till yet. Will be asking a lot more questions all over, and hope i can do my but and help out wherever i can.
Cheers
Ps: this wasnt diy. Had a sound expert do up the install for me, and sorry didnt take pics as i was too freaked out about something shortcircuiting or frizzing up
