Tell me more about the air cylinder locker actuation setup. How is it attaching to the diff housing? Did you machine an extension shaft that attaches to the fork?
I used this cylinder from automationdirect http://www.automationdirect.com/adc/Shopping/Catalog/Pneumatic_Components/Pneumatic_Air_Cylinders/Compact_Air_Cylinders_(C-Series)/1-1-z-16_inch_Bore/C170075D
I drilled and tapped the Toyota housing for the 6-32 machine screws that go through the cylinder and added a spring inside the cylinder to give it a default return function. I then had a shaft machined to mimic the e-locker shaft, that was threaded to fit the cylinder. I have about $80 in the cylinder, switch and fittings. My dad did the machine work on the shaft so that didn't cost me anything... yet.
I didn't care for the one Ash was hawking. It required a mounting plate and looked kinda flimsy. This is compact and rugged looking.
I used the 3/4 stroke and a spring internal with a compressed length just shy of .300, that gave me the desired stroke. The plug has a small hole drilled in it as a breather, a vent filter would be a better option for the long term.
sexy indeed.....Terrill is putting off home projects for too long
Do you mind pointing me to the spring you used? If your dad is up for it, I would be more than happy to pay him a fair price to make me 2 shafts like yours?
I think Terrill just found a side-job. Buddy, you could sell kits and 80 people would drink them up faster than Shiner Bock.
Sshh!!
I have an extra spring. I picked them up from Ace hardware and I have the drawing for the shaft. Granger has the springs but they had to be ordered and patience is not one of my virtues. http://www.grainger.com/product/Com...m/rp/s/is/image/Grainger/1NCD3_AS01?$smthumb$
and a link to the valves I am using for this and my front ARB http://www.grainger.com/product/ARO...m/rp/s/is/image/Grainger/3NB16_AS01?$smthumb$
I'll inquire as to a fair market price for the shafts.
Would need to be a bolt in package mounted to a plate that replaced the actuator and it would only work if the 8" version uses the same type of actuation/linear movement for the front axle.
It would need to be a complete package for wide spread koolaid consumption to take place
I like that switch. I can see the knob engraved with F/R locker in white to match the rest of the knobs
