Less Lift? HELP ME!!!
PO said the FJ40 has a 4" skyjacker lift.
My springs are rusty.
It has 6" shackles :eek:
THe fenders have been cut but since it only has 33s on it, the 33s kind of look small. HOW CAN I MAKE MY CRUISER LOOK PROPORTIONAL???
Can I fix this by putting smaller shackles in?
Would I have to change the shocks then?
Should I just put a new lift suspension in it?
I really don't know all that much about this, so please help me!!!
THanks
Al :popcorn:
get 35s
if you are worried about porportions
personaly i would get different shackles. you have pics?
no wait i would go soa and not other way
honestly, it does'nt look that bad.
get a shorter shackle at least.
general question/hijack.
why is it that most 40s' shackles are straight up and down?
pssssst, don't listen to camcruiser.........
:mad: :flipoff2:
after looking at the pics i agree that it doesnt look that bad.
let me help
6"shackles? Those look like 3" to me. Which in turn gives 1.5" of lift.
My vote is the same as most everyones, get a stock lift shackle set up and be done...
:cheers:
Hmm..
Looks like my springs and shackles are all messed up.
I'm not sure what I want to do/should do / will be the best
Options:
1. Replace suspension (would it be funny to go to 2.5" lift from a 4"???)
2. Get 35s
3. Try to just replace shackles
Replacing Shackles
What size shackles should I get? I think I have some 2" ones in the parts bin I could try.
Maybe MAF 4+ greasable shackles
http://www.man-a-fre.com/parts_accessories/4+plusGSKsuperdutyHDgreasableshackle.htm
THE MAF Look Pretty nice. Do I buy just for the rear?
Should I get the anti inversion ones? This makes me believe so:
https://forum.ih8mud.com/showpost.php?p=1601348&postcount=9d
Any particular kind? I see some different kinds and shapes:
http://cgi.ebay.com/ebaymotors/TOYO...018QQitemZ280068826536QQrdZ1QQsspagenameZWDVW
CCOT ?
http://coolfj40.stores.yahoo.net/shackletri.html
Shackle Reversal?
http://cgi.ebay.com/ebaymotors/Land...004QQitemZ140073037883QQrdZ1QQsspagenameZWDVW
WOW! SHackles are pricey. I might just try the used ones I have lying around.
How do I replace the shackles?
I am looking at a manual (Haynes, Yes I have FSM but couldn't find anything)
on pg. 151 it tells how to remove the rear suspension. If I am only replacing the shackles can I just unbolt the shackles nad take the rubber bushing out? Or do I need to do anything else? Seems easy enough.
Thanks and sorry for the stupidity!
Yes, but get new bushings and get greasable pins while you are at it, and don't overtighten your new shackles. Search the subject, you will find what you are looking for.
$$ You can make your own very easily if you have the tools.
