leaky head from power steering conv.
tunica, ms
i started my power steering conversion lastnight and when i pulled the two bolts from the head coolant started seaping out from the front driverside corner between the head and block. i'm hoping there is a water jacket there and it will seal up when i bolt it back down. anyone have an opinion or experience on this? it stopped seaping after a few minutes, but has me concerned.
this is the main problem witha that bracket. I think that you should have done it with the motor cold and i would of done them one at a time. ho well might as well undo the rest of them and chang you the headgasket. once its breached it will never re-seal right.
Trollhole said:
MIne worked just fine. You need to do it cold. Cannot do it one at a time. Both bolts have to come out. And retorqued to specs.
Although I did not use that bracket, I still removed the old aircleaner bracket and had the same leak. I just did like Trollhole and had no problems. Worth a try, anyway.
Ed
The safest way to mount the PS pump bracket is with the engine cold and the radiator cap off so there is no pressure. Before doing that I would take a torque wrench and see if both bolts are to their proper torque. If they show they are below the torque called out in the book, then I would remove the valve cover and pull the rocker arm and re-torque all the head bolts prior to adding the bracket. It may seem like a lot of work, but compare that to changing out a head gasket. If you get a coolant leak and you just put the bolts back in is asking for a blown head gasket.
I've removed the front twop headbolts on a number of engines. Never caused any problems. One or two of them leaked a little fluid while the bolts were out IIRC. Reinstalled the bolts with the bracket or air cleaner or whatever other reason prompted the removal and moved on. Never had any problems down the road.
Mark...
