After recently changing out an aftermarket SW fuel sending unit, I have not been able to get the new unit to seal. I used Permatex "Gray" gasket maker, which is supposed to be fuel resistant on both sides of the gasket. Was that the correct thing to do? I suspect that when the tank is full that the sealant is not able to resist the constant contact. Is there a better material to use? Or is the gasket supposed to be mounted dry?
