- Thread starter
- #21
My 40 began life in 1968. We had a SBC 350 conversion done on it in the early to mid 1970s. It was probably in the 1990s that I switched from the stock toyota gauges to Stewart Warner ones. At that time it was necessary to switch out the fuel sending unit. The truck sat unused from 2010 until recently. As part of the process of bringing the vehicle back to life, I found it necessary to replace the sending unit. This is the one that I am having difficulty getting it to seal......What yr 40 do you have?
OEM Fuel Tank Sending Unit for '66 to '72 Land Cruiser FJ40 FJ45
OEM fuel tank sending unit for '66 to 9/'72 Land Cruiser 40 Series. Compatible with F engine. Gasket and screws are available separately. Technical note: This sender isn't "resistive". It works like an oil pressure sender, with a bimetal points type regulator it it. The float moves the contacts...www.cityracerllc.com
