Can those without power lift gates tap on reverse camera cable for power?
Plus, I believe the camera is 6v, not 12.No the amps are not there for it and the wire is too thin.
Can you use your rear hatch kit as well as a light kit like this on the same rear hatch? Trying to decide which is more important to me. Not enought room in that access panel, i wondered about mounting both switches in the access panel and the light just outside of it nearby.Edit: I see now this kit is replicating the light kit referenced in the OP. I was wrong in assuming it was referring to our rear exit switch/handle kit that uses OE parts. Fridays![]()
Someone in the LC200 Facebook group got it working:Well it came. And of course it doesn’t fit on my 2011 land cruiser. Last picture is my plug on the cruiser.
Hmm wonder what year his is. Supposedly if you have a newer one it will work. Power gate. Mines an 2011. What’s the fb group?Someone in the LC200 Facebook group got it working:
His is a 2020-21. Makes me wonder if it wouldn't work on my 2016 also, since it doesn't have a power gate.Hmm wonder what year his is. Supposedly if you have a newer one it will work. Power gate. Mines an 2011. What’s the fb group?
This is perfect. Just ordered the light but will be using it with a push button switch.View attachment 2844051So I wanted a rear hatch light that was supper low profile and that looked as OEM as possible. I emailed VLEDS and they were kind enough to create a link for a single puddle light and adapter (6”) for my application. $32 + s/h later and and 5 minute instal and I think it turned out awesome!
5500K WHITE UNIVERSAL AND FORD PUDDLE LIGHT - https://www.vleds.com/catalog/product/view/id/3778
PIGTAIL ADAPTER 2 PIN FEMALE + DUOTAP - https://www.vleds.com/base-adapter-2-pin-waterproof-pigtail.html
So I wanted a rear hatch light that was super low profile and that looked as OEM as possible. I emailed VLEDS and they were kind enough to create a link for a single puddle light and adapter (6”) for my application. $32 + s/h later and and 5 minute install and I think it turned out awesome!
Ordered! Thanks @Gr8Daneger, but curious where you tapped into power also.
I only found constant power at rear cargo light and tapped that for hot and took ground off 3rd brake light in my 08I put one of these in my 40. Works great. Think I got it on amazon it does white and green. Thinking about mounting one like you did in this thread but mine is an '08 and not sure where to tap into power. One nice thing about this one is that the switch is built in.
LED Dome Light, YCHOW-TECH Universal Roll Bar Mount LED Light W/ Switch Car Inte | eBay
Find many great new & used options and get the best deals for LED Dome Light, YCHOW-TECH Universal Roll Bar Mount LED Light W/ Switch Car Inte at the best online prices at eBay! Free shipping for many products!www.ebay.com
were you able to fish the wire through the factory rubber wire loom?I only found constant power at rear cargo light and tapped that for hot and took ground off 3rd brake light in my 08
Yes I was. You're talking about thru the rubber grommet you can see when you open the hatch right?were you able to fish the wire through the factory rubber wire loom?
