here is the install guideHi Ricky can you send me the video link for installing the MAF .
Thanks Greg.
Thanks Greg.
Hey Rick- You were right, pin is loose on the MAF sensor pin. The leaf that you said to bend is not immediately clear to me. Can you provide a little more detail on this procedure?It’s most likely the pins in the connector. Over the years the leaf springs in the pin relax. Take out the pins and use a tiny flat screw drive to bend the leaf and add some pressure.
When you first pull out the pin slide it on the MAF sensor pin, you will likely feel a loose fit until you bend the leaf.
Many thanks to Rick (Landtank) for his support in troubleshooting an issue with my Gen-IV MAF. After eliminating other possible explanations for rough idle, he diagnosed a bad sensor and sent me replacement. Problem solved.
Customer support is a problem with many major corporations these days. Rick is a one-man operation, and his willingness to call and text me until we had the issue resolved was really exceptional. Very much appreciated.
BTW, the fully operational Gen-IV MAF has improved overall throttle response and smoothed out the idle on my truck versus OEM MAF. No data yet on MPG.
X 3I'm with amay3, my service and support experience with Landtank is top shelf. And yes, my SC'd Landtank modded 80 never ran better.
93-94 doesn’t have a MAF, but an AFM. A company called Split Second sells a conversion kit for the earlier 3FE, but not our engines.Can anyone point me to a source for a MAF for a ‘94 FZJ80? The shop doing some work on my truck said they are no longer available through Toyota.
forum.ih8mud.com
How do you like the upgrade and impressions?X 3
Landtank offered great support on trouble shooting his products; I recently upgraded from his Gen II MAF to his larger Supercharger MAF with scaled injectors.
Excellent customer service!
Thank you for the quick response. I’ll check out the link.93-94 doesn’t have a MAF, but an AFM. A company called Split Second sells a conversion kit for the earlier 3FE, but not our engines.
1992 Land Cruiser MAF Conversion |
splitsec.com
This guy rebuilds AFM’s and does a pretty good job from what I’ve heard. This would probably be your best bet.
88-94 Land Cruiser VAFM REPAIR SERVICE
forum.ih8mud.com
I like it. Throttle response is better as is the drive ability.How do you like the upgrade and impressions?
I have the kit but not installed yet on my s/c’d.
Are these still available?
