Was there a known problem with the design or something of the FJ60 calipers from the factory ?
The reason I ask is that in my front axle work, initiated by a leaky and seized passenger side caliper, I am finding the driver's side caliper to have seized (but not leak) in the same piston as the passenger side caliper. It seems one of the smaller bore pistons View attachment 1436839 View attachment 1436840 on the half without the actual brake line connection seized in both. Is this just shear luck in dealing with a formerly 1-owner 1983 FJ60 with 283K miles or was there some known defect pattern?
I have the OEM seal rebuild kit, 8 new OEM pistons, the ever-elusive red "Toyota rubber grease" for lubricating all things in the pot all made affordable by ayamaya.com. I am also using a different grease than the red rubber grease for the pins etc. stuff not in the piston pots. I am weary of unknown rebuilds and have rebuilt calipers before, just not for an FJ60, so I actually prefer to go this more expensive seemingly illogical route haha.
Below I am showing the driver's side caliper, with the formerly seized piston evident in it's difference from the other used pistons. I am lazy and don't want to scrounge for the passenger side but the effect was the same. While ultimately the driver's side was in better shape than the passenger side, it still required me to use heat to try to remove the stuck piston, which didn't work so well, followed by letting it sit 3 days submerged in a bucket of evapo-rust. Evapo-rust was my hero.
