knock-knock
Santa Rosa, California
Fresh rebuild, not by myself. Mounted into my cruiser and fired up. After warm-up it developes a knock, a slight tick at idle and a pronounced knock when revving. I have been in and out of this engine about five times now, connecting rods & pistons good, bearings good, push rods straight, rocker arms tight, valves check out, distibuter fine, everything in the engine looks good, but still knocks.
ANY SUGGESTIONS, all input welcome!!
Thank you.
:frown: Michael
"bearings good" Did you plastigage all bearings? Check crank for straight?
Did you check main bearing bore in the block for straight? Wrist pins, wrist pin bores? You should be able to narrow down where the knock originates by using a stethescope or a long screwdriver to the ear.
Did you have the crank magna-fluxed? I think I've got your motor in the back of my truck. Same thing. Runs, but knocks. The crank has a crack in one of the counter weights. (So I was told by the PO.)
Does it still have the same cam & lifters that were in the motor prior to the rebuild (re-ground of coarse). Once I rebuilt a 2F motor and used a re-ground RV cam and lifter set (non-native to the motor). Had a pretty good knock that got a bit louder at increased R's. Turned out to be a connecting rod bolt slightly hitting on the cam (between lobes). Pulled the cam, turn that area, re-installed and OK. Engine noises can sometimes be a bitch to track down, since noise travels through the motor.
Also check cam and crank thrust. Could be walking, if out of tolerance.
all good leads checked them all, bearings plastigage ok, connecting rods all good, wrist pins tight, listened all over with earpiece, sounds like it comes from the front of the cam area.
Do not know if original cam or not, tonight I am going to see if there is a long motor mount bolt protruding into the crank or cam chamber, other than that will proceed until I find it, hate to waste a good engine, keep all the good leads coming.
Thank you All, it is nice to know people are still willing to help out.
Michael
NO! due to my rookie status I did not know about the FAQ.
I THANK YOU for the link, looks like I have some good reading to do. I will keep all informed.
Sad for me to discover but the motor mount bolt holes do not even go into the chambers at all, they are all blind holes, well at least I now know.
Michael
PabloCruise said:
Exhaust leak?
x2 - I had a very noticable knock (that become most audible after revving or driving a big hill) until I found there was a loose bolt at the headers.
Did you re-adjust the valves, or at least check the lash after warm up?
YEP!! adjusted them twice due to the fact that I really wanted to check all the push rods for straightness, after adjusting them the day before, a couple of hours found all rods straight, but now I know.
Bought new timming gears they should arrive today, busy tonight should be installed sat at the latest, after reading the links from Poser on timming gear issues (thank you Poser) I believe this to be the final solution, but we will find out in the next couple of days.
RUBITHON next week.
Well ok, today I got my new timming gears, and then I said screw everything, pulled the cruiser into my steel shop and proceeded to tear the front end of the engine down for a fifth time. Now that I have installed new gears and replaced the broken Cam Thrust Plate all is now quiet again.
I THANK ALL of you that gave me input and in the future I will gladly pass along the knowledge I have learned during this experience.
So it was the timming gears after all
Thanks again to everybody that helped.
Regards
Michael :) :) :)
