- Thread starter
- #81
Redid starter power wire, winch power wire and engine ground with 1/0 wire and wrapped with 1/2” spiral wrap to prevent chafing. Added new military style battery clamps, cleaned up wiring some.
Excited to get the tires installed and doing all the fluids, seat belts, console. Getting close.
. What model of interstate battery are you running?
to assist with the last bleed, the clutch. Also adjusted/ tightened loose mirrors with a trick I think learned from Mud. Works amazing. Took it around the block for a slow run. Everything works. Brakes are tight, clutch is smooth, steering is tight, easy to turn the 9.5” tires. Tires are quiet. Brakes did not get hot or bind.
