Just did HG with all the goodies and still loosing coolant : (
First time I noticed it the reservoir was dry and the radiator was low. The tubes were still covered but just barely. So I filled them both up then and have added to the reservoir at least 5-6 times but it has not been totally since the first time.
Ok, that's a little more! Something more than trapped air bubbles.
Heater core is the only thing not visable at this point.
Does your local part store rent out a radiator pressure tester?
Have you tried burning off the condensate in the oil, dump it & swap fresh oil - just to prove out it's going there?
Or have you had ~2 oil changes since the refresh gasket & this keeps eating coolant?
Did it run proper at all, or is this straight up how it has been since the HG work?
I though about the heater core but I don't smell anything in the cab and I did shine the UV light under the dash and in the passenger side foot well looking for dye and didn't notice anything.
Only one oil change since the hg. I noticed a small amount of goop under the oil cap 3 days after the work was finished and thought it might be a small amount of residual coolant burning off but a week after the work the goop was much worse. The goop wouldn't worry me at all especially this time of year if not for the coolant loss.
I don't think so, I don't see how it could be. It was obvious that someone had been in there before.
Is it common for the head gasket to be this mis-shaped around the cylinder? Looking @ the 3rd pic in the post, that gasket is all kinds of not round!
those piston tops looked rather clean- its been opened up for sure prior to your job.
Running super/92 & Techron treatmemt can lift the carbon if that's what you see (I'm on a phone, riding highway)
Just saying as I borescoped mine yrs ago (new tool in refinery, I wanted to play with)- to see if Techron did as claimed (it does, but you gotta run a bottle every 1000-1500mi to keep spotless). But it does do the piston tops, I expect the valve bells cleanup too. Just my experience.
And blowing a HG (guessing #6 blew) - fogs you a good 'steam-clean' on that one. IDK.
I do recall a couple days in atmosphere with the head off mine & carbon on the pistons (pre HG, regular 87 & no Techron, ~2002/03) peeled up like latex paint & lifted spotless with a rag & WD.
Firm believer in techron as well, great stuff! Neighbor owned a Chevron forever and brought us a bottle here and there. Helps ever so slightly for smog as well. I always try to run some after a trip with a random gas station stop, keep the path clean on the top end.
Just a thought, but are other cylinders overly large or out of round on the gasket? If so, I could be to take up some added cc space from a deck height job, if, that wasn't achieved by the hg thickness? .02¢
Mine did exactly that, peeled up and flaked right off. First pic is immediately after the head came off. Second pic is a couple days later.
Yes there were a couple more that did look very out of round, struck me as odd right off the bat.
Hi, I'd try swapping in a good oil cooler and see what happens. Visual inspection might not be good enough. Mike
That's what I have been hoping since I initially started loosing coolant. Just figured since I was going to have the manifold off might as well go ahead and do the hg as well. You bring up a good point about the visual inspection might not being enough, say it was cracked shouldn't I be getting some oil in the coolant as well?
If I recall, New head gaskets are out of round there too.
