Johnvee's 80 thread
Dont forget to do between glass and rubber, then rubber and metal.
New tires is going to mess me up, I can always find your truck when I look for the bald tires, now I have to reset my system...
I'm gonna try it first with only the window to gasket. I'll do the gasket to metal if that doesn't work.
I'll find a way to be more recognizable for you. Maybe some bull horns on the hood like a 1970's Texan's Caddy?
...via IH8MUD app
Update time:
March 2016 I blew out an o2 sensor when one of the studs broke off. Timmy at A1 Exhaust in Fort Mill, SC welded in new bungs, used new hangers and replaced everything back of the cat. $160 well spent. The local Meineke wanted over $800. Thieves.
August 2016 Went to the HAMOM at Dave Rushing's place and replaced the radiator and all related hoses & clamps (OEM from @beno). Kept the 3-yr old thermostat that was already in there. Put in new green coolant since that's what was already in there. We removed the fan and shroud but didn't have to mess with the belt tension. Also replaced the crusty, leaking O-ring on the distributor. Also checked torque on all bolts regarding steering and braking.
Tires.
The BFG KO2's are holding up well after 9 months and maybe 3000 miles. No signs of cracking tread like some people are recently reporting. I've only had them in the dirt three times - all easy trails - and have nothing to say except that they worked. I hope to get to wheel at Logan's Run this year and will try some harder trails. I'm sure they'll do fine. They're very smooth on the highway, WAY quieter than my old Hankook MT's and handle rain and slush well. I felt so much safer in the couple of winter storms I drove them in. I decided to do a 5 tire rotation with these and just knocked out the first one.
Storage.
I'm reevaluating my storage/sleep system that I made back in 2013 (and never posted much about). Can't find a pic right now other than a partial in post #51. I yanked out the 2nd row seats. It's been great but it was designed around being a sleeping platform for two people (the IKEA futon fits perfectly after trimming 3" of length). I made it just tall enough to hold a 1 gallon water/milk jug in the 'drawers' but I stopped sleeping in the truck over a year ago when I started feeling claustrophobic. It's also a pain to exit and enter via the side doors in the middle of the night while barefoot. Even worse for short Sarah. Especially bad when combining the sliders with bare feet, plantar fasciitis, arthritis and winter temperatures. I'm really missing cargo room lately so I might try to remove some of it and modify it a bit to the plans in my head.
Bumper.
The 4x4 Labs rear bumper has been great. It's no secret that I consider it mostly as a spare tire carrier. An expensive one. But it's built like a tank. Yes, it's a pain to open and close every time I need access to the rear interior. The ladder on the PS serves mostly to mount the HiLift and the license plate. I think I've climbed it twice. It probably will be handy if I use the roof rack more, but that's normally accessed from the sides, so it's doubtful. I'm gonna put a couple Quick Fists on it for my shovel at Logan's Run. Running the spare on the bumper does limit my use of a cargo carrier in the hitch. The spare largely blocks the DS half of the carrier unless a loooong extension tube is used, but there's still a problem because the swing arms won't clear the rack if it's loaded, so you can't drop the hatch open.
Roof rack.
Heavy. ARB steel model. I'm happy that it doesn't seem to make any noticeable noise. I was worried when switching from MT to quieter AT tires but I just can't hear it. The size is very convenient, and so is the mesh floor. I'm overly anal about strapping things down; the mesh gives plenty of places to do that for every item. My two 10' kayaks just barely fit side by side, upside down, without any kind of additional mount. I strap a fishing rod carrier (4" PVC) to the side sometimes when I wish I was an architect. I really can't say if a flat rack would be better than a sided rack, I only know that I like the peace of mind of having the sides as cargo barriers.
Dammit. The 80 pulls to the right when braking AND also doesn't feel like it wants to stop as quickly as it used to when reversing down my driveway. That last part might be in my head because it still brakes well going forward. Good time to replace my lugs and nuts while I'm in there, I guess. Double dammit! I just cursed us with crappy weather starting whatever day my parts arrive.
Shall i call the wambulance?
Man up! Youre no rover driver. Get out there and do it!
But if you are not doing rotors then you "wont be in there" so the procrastonator inside you should be fine skipping it ..... until visions of nclx pop into your head an hour into the Portsmouth drive.
Your welcome :D
Remind me, did you already have new calipers and pads all around? I recall you mentioning something around that.
I had one of my front calipers sticking, would pull on braking as cilinder wouldn't move. Napa front rebuilts fixed it.
I had a piston in the passenger front seize up on the 450 last fall. Got a nice reman (from an OEM appearing core) from napa.
On the white 97, i broke a stud (got careless with the impact gun after a very long day). Debating on doing all 6, or just the broken one. I dont want to hear "do all 24", cause I got plenty other things to do on it first.
How much did you pay for the lugs and studs?
Lugs and lug nuts at Scott Clark Toyota. Can't say I'll use all the lug nuts. I'll hold on to them in case anybody needs some.
Exactly why i never ordered 24 of each !
Though i need too. Now on to rebuilding that front axle again.
Plans to seat the lugs? Stack o washers and the lug nut? I had issues lining up the press to get them in without the hub becoming unstable in press
@Izzyandsue Then mine will be 2.328 times more awesome than yours.
@jfz80 I don't have a plan for seating them yet. I'd probably lean towards the washers/nut idea because I have those and I don't have a press, and I bet I'll run into the same problem as you if I go through the trouble to hassle somebody for the use of theirs.
Ugh. Just realized I forgot to get caliper rebuild kits.
I got a press you can use.
Just food for thought after rebuilding mine vs seeing the OEM rebuilt castings we got for James at napa at ~ $55 ea I'd be tempted to test the rebuilders reputation and grab a set
Just ask them to open the box and verify you got a xx04 and xx05. We had two pass sides but boxed as left and right.
I got aftermarket rears 4 years ago out of fear of learning how to rebuild a brake assembly. Finally ordered the kits this fall to renew them after realizing I could do it. Didn't know the NAPA's were only $55. Pretty sure the rears were way more though that doesn't make sense.
