Is this right?
Bogota
Does this pic look alright to you?
Something looks crooked.
Fluid of some sort leaking too
This may be a dumb question, but, how can you tell it is out of phase ?
you can see the u joint mounting ears are not lined up correctly.....could create vibrations.
And a wire hanging down, not sure about that front brake line, must be a RHD. OP, what are you seeking?
That's a lot of leaves in those rear springs. And you're either missing or have a broken front bolt on the skid plate.
To see if the drive shaft is straight. It looks off by about 45 degrees to me too. Never seen that before. It drives straight though...
Not sure what you think is crooked. It might be easier to see if the vehicle was sitting on a flat surface.
The back shaft is straight. The front APPEARS to tilt up at about 30 degrees but damned if I can telll
The wire....I traced it up into the engine compartment, then underneath the firewall, and into the top of the bell housing...
Probly. I haven't gotten under it yet. I was halfway through the engine rebuild when my mechanic died of cancer. Never got to the bottom end, (there's a knock), we just did the top...don't know what the hell to do now.
