I must give credit to "Australian 4WD Action" magazine and "Roothy" (the magazine's key contributor) for finally getting me to look under my cruiser and check my driveshafts for their "yoke alignments".
My back shaft is easy to photograph and it conforms to what the magazine refers to as "having the yokes in the same plane".
(I've drawn a cross on each yoke so you can see clearly that they are indeed in alignment.)
Now, to my astonishment my front drive shaft is set up exactly the opposite. Its yokes are 90 degrees out of alignment!
I'd show you a photo but my crossmember gets in the way of photographing it.
My question is - Should I alter the front to match the rear (where the yokes are aligned)?
According to "4WD Action", unless they are aligned correctly - the shafts will cause vibration problems. Yet I haven't noticed ANY vibration issues with my front driveshaft!
Any words of wisdom would be much appreciated.
