Is this normal?
Modesto, CA
Check out the pics below. I can't imagine this is how it came from the factory.
I can't say that I have ever seen connectors like that used on a factory engine harness.
Umm not normal looked like third grader wired that up I'd get rid of that asap , what is all that suppose to be going to anyways
Definitely appears to be the neutral safety switch/ gear indicator switch. And that definitely looks like someone hadn't the foggiest clue as to how to disconnect the plug and decided to do one of those tweaker stereo jobs on it.
Wow that's ugly. Not much you can do without a new harness. Cut all that crap out and do it right at least. Solder all the connections including shrink wrap. Then wrap all the wires together with electrical tape. Maybe some wire loom to finish it off.
what year is that off of? I might have a used harness.
Oh, a Lexus…. LX wiring can be different… hate to sell you something that will not work. If you figure out it is the same, I have a 96 with a full harness. Shoot me a PM.
Looks like wiring to the neutral safety switch. I think there is a plug where the bell housing meets the engine on the drivers side. If you disconnect that plug you can get that harness on the table and take your time to resplice and rewrap it.
I have a 97 lx engine harness but I can't tell from the pics exactly what is going on. Might need a tran harness also.
I bought the LX with a blown HG. Motor had been rebuilt and it was a half ass job but charged a premium price. This is no doubt the result of there "workmanship." Good news is that it's headed to valley hybrids for the motor swap.
I am new to the 80's, but I have had to fix lots of wiring of previous owners on projects over the years. I used to replace the connectors on my salt truck back up zombie lights every fall until....... I discovered they make crimp connectors with solder in them. Double wrap them with shrink tube and you should be golden. Before that though I would try to find a new or used harness that's not hacked up. That looks like S#*+
Multilink™ Sealed Crimp and Solder Butt Splice Wire Connectors and Ring Terminal Kits - CableOrganizer.com
I have seen worse. Seriously, I saw a rig that had a HG job done on it at a shop that did not know anything about 80's. They CUT all the way thru the main engine harness by the water heater valve instead of disconnecting it from the computer.
My frustrations isn't from this single incident. This was supposed to be a fun build, just needed a head gasket and it had ballooned into, new motor which of course needed a rebuild, the 4x4labs bumpers that my welder was supposed to have done in a few days had a heart attack and I just got the vehicle back today without the bumpers and sliders complete and s*** welds. Looking at it, the front axle probably needs a rebuild. But thank god, it has new brakes.
