Is this normal?
Had something similar done by the previous owner on my 93's neutral safety switch. It had silicone gobbed over all the wires.
Ended up finding a used connector with a bit of a pg tail and spliced it in properly.
OfT32N2Aliii8zEqyftIA00pCZ-zdeqT8r9RBXeNhZ2pm_Gqayz86w7xNmbZVj2tO60JUq8hdQBQQIgOp7AFwnqQN73K6262LSRt23uwIMwEWvFImbmma8gTLSsk3p97Dpp5n1j5D52Wb6CNlyI9EUY8tUddTbgy9FlPsMtzg3wTm1aT4M8Gpna3mtOYsSXP4yNmkFw4l9Lu45VgjdeI7OID01gnTOO__dlf5jpreGlk_puTszUg1cIoLDj20Oql2rNC3ZQvEUiubX2qxCxjgIxSi5Z7pmBIa2GmyqagFe27_CmtepEY9akA8Mmgd7KAqYlOz9ElJeWaldy_G1nFgFUVQmb_2i0S1sxpCx6XW3n9vouZ3EkPzO0iwYOA99xBSORtcABPyUonOhssz_S6EviJYARSBOqRNa4ARc0TgZvxgdHrR_pem-PQtyYMCWOtOyJVvSJXwj8yklyrSvSe0NugMTvzeYueK8KZkcQsDZl6jjzVp3P_ZHvH7U_8gIpTcRESvPThrZ2_kPog483HCZw0s-66mycbmqjaKuu2LdQFbNucAaRwSnZaoSmlBPNVz_dgWRKJR0VvKIvb1uuQBq8y1Km5w11EnKZ82Ld83TaDMZKax6cR=w368-h654-no
I've been there, it sucks. Just keep on going. Keep telling your self new vehicles are expensive and that they don't make them like this anymore.
I am new to the 80's, but I have had to fix lots of wiring of previous owners on projects over the years. I used to replace the connectors on my salt truck back up zombie lights every fall until....... I discovered they make crimp connectors with solder in them. Double wrap them with shrink tube and you should be golden. Before that though I would try to find a new or used harness that's not hacked up. That looks like S#*+
Multilink™ Sealed Crimp and Solder Butt Splice Wire Connectors and Ring Terminal Kits - CableOrganizer.com
I have to agree with you about the quality of Multilink connectors. My son gave me two different multilink kits as a gift, I, like you, always solder and use shrink tubing. Using Multilink connectors will save you time when doing repairs.
i promise you it could be worse. i have seen all kinds of crazy things over the years deal with 80s and parting them out. some of the alarm systems and aftermarket head units are the best. 20 new wires and all the same color ;)
