In sailing world the joke is new line goes to the running rigging. Once those are shot they become mooring lines. After that they move to the bedroom.
considering that I just did my rear hubs this past weekend at 220k and there was NO grease at all in the bearings, they were running in gear oil. I think you could just spit on them and get 100k. YMMV
Are you saying the gear oil is good for bearings?Most of them we have seen had no grease, were running happy on gear oil. Have left the axle seals out, so the gear oil can flush in and out, works well and is how most FF axles are done. Gear oil is a better lube than grease and no need to repack.
And here I was going to pack moly in the carrier and pinion bearings Most of them we have seen had no grease, were running happy on gear oil. Have left the axle seals out, so the gear oil can flush in and out, works well and is how most FF axles are done. Gear oil is a better lube than grease and no need to repack.
And the hub seal does a good job of keeping it out of the brakes?
Do you leave the inner seal out on all the rigs you work on now?
Yep, most of them we have had apart had no grease, full of oil, so no real change.
Depending on owner preference, mostly yes.
Just curious, but why would there be a different grease for disc wheel bearings vs non disc wheel bearings?
